Torque converter stall speed
Stock should be approximately 1800-2000rpm. Check by setting the parking brake, standing on the brake pedal, put the gearshift in "B" position (first gear), and press on the accelerator pedal until the engine RPM does not increase further.
:watermelon:
:watermelon:
then Release....!:)
LOL! Yeah - don't do this for more than 3-5 seconds or so. Not good for the components.
You played w/ Semi rigid mounts (urethane filled) yet? You can Notice the snap-to/response is improved. You can retain Most of the factory levels of NVH if you leave the trans mount empy/unfilled..or perhaps w/a Soft grade of urethane though i haven't played w/ the latter setup yet.
I'm going do the solid engine/stock trans mount in the brumos car. Just need to find some time. Perhaps do it @ the same time as the diff...which will likely wait until the new rear bars are available... Slippery slope you say??! Jeez..
Ok, back to work!
jono
