Hello 500Eboard!
So far I'm loving my new 500E
My girlfriend and I are liking more than my modded '03 E55K
, the 500E is just so smooth!
Anyways, I just serviced the transmission fluid and filter. Fluid level is perfect max after being driven.
- Unfortunately, when I get on the kickdown switch on the freeway (let's say ~75 MPH), it downshifts, then around 5K RPM, it'll bounce as if I'm hitting the rev-limiter for a second or two then continue accelerating.
- Another issue I'm having is when I'm cruising around 30 MPH then floor it to the kickdown switch, the transmission slips so RPM is high and will stay high until it matches wheel speed then continue to redline. I'm not sure if this is a 3-2 shift or 3-1 shift, I am pressing the kickdown switch.
- Also just to confirm my RPM's at ~75mph is at 3K, is this correct?
Hope you guys can help me out!
Thank you,
AJ
Thank you,
AJ
