Twin-turbo 500E, claimed 627hp and 670 lb-ft at 13psi boost
gsxr
Russians are the most fanatical MB enthusiasts I know. Perhaps it's because they were are hungrier and think outside the box. I saw a thread where one guy converted a 6 speed transmission to fit in his 500e. And here in the states with the access to many machine shops and car enthusiasts, all we have to show for our desire to have a manual transmission in a 500e is in that light blue 500e with the Renntech manual transmission swap . . . .
The twin-scroll turbo setup reminds me of the Sauber M119 twin-turbo.
Insane!
http://www.benzclub.ru/forum/showthread.php?t=447&page=151
:-) neil
via Bing Translator:
Donor BMW transmission: 2005 BMW 5-Series
Donor Mercedes M119 Bell-housing and pinion for a speed sensor
With clutch was two ways or custom, but then the engine management wizardry or original Mercedes. The flywheel with the basket helped found American partners who implement the project rather amerikosy helped found the Poles, who knew how to help. Rooms were cut down on the details I was not involved in the search for possible refinements and part numbers, I had enough of the words my friends, that is structurally stronger than adhesion Kit BMW for that box in the end everything was in its place, the crankshaft sensor was left in the same place and the same. Disk scepy from BMW 240 mm diameter, diesel.
In the end, the car was on a ski lift, was revamped tunnel box, it boosted up that you could reduce the shift lever moves with the same tunnel would widen the screw drive cardan. It came out very ergonomic and BMVešnomu briefly and clearly.
By the way, I have been browsing the entire thread. Most of our members have their cars posted. 2phast's over several posts :)
