Mod Note- same lifters in m104 and m119 etc so this is relevant to the 500E hence not posted in off topics but if you prefer to move that's AOK
So after about 2 years likely I have been cleaning the garage and started up my E36. (W124 with 3.6 C36 AMG engine swap)
It is a really clean engine inside- always was! But it was always prone to valve lifter noise. Cured by several starts over time and sometimes valve lifter additive.
This time - ohh dear!! Severe valve lifter noise from maybe cylinder 5 or 6. Terrible noise. Took oil cap off and there is plenty of engine oil pumping so dont believe there is a oil supply issue. (Since C36 clocks installed too no pressure gauge. Will add one at later date. Indeed I plan on using a m104 w124 cluster now instead)
Anyway after a couple of cold to hot warm ups it's still clattering its head off. I believe one or more lifters has totally drained of oil from sitting and will not pump back up. This sucks! I should not have let it sit so long but was avoiding moisture in crankcase from cold start ups.
Anyway I always had lifter issues with that 3.6 so it needs addressing now more than ever. Need to check if these lifters are AMG specific but in any case found this video and I find it very interesting. This should be the answer to properly clean out and find/ clear the sticking lifter(s)
What do you guys think? I have so many projects now that I do not want to simply purchase a full set of new lifters. My preference is very much to strip, inspect and clean the original lifters
