Just an FYI and something to look out for...
When I washed my car, I noticed some condensation inside of the tail lights. In looking for the source of the leak, I found a small amount of water on top of the tail lights inside the trunk. At first, I diagnosed it on old tail light seals and replaced both sides ($24 each side). When I removed the old seals, they were just fine - pliable and soft.
Yesterday I washed my car again and found water in the same spots. I determined that it was coming from the bolts on the trunk alignment tabs. Clearly the gasket has aged and is leaking. I'll replace those next.
Leak is getting past this and dropping onto the top of the tail light.
Picture is fuzzy, but there is a droplet of water on the bolt.
Water pooling on top of tail light.
Fortunately, there was no long term moisture in my trunk and no rust. Keep your eyes out for water!
