Hello all
Finally put down a deposit on a 1992 500E in 744 silver with full black leather. I live in London, United Kingdom and the car has recently come from Japan. I have bought it unseen and the car is currently being registered on UK number plates.
Can anyone decode the VIN? Keen to see whether it was a German or Japan market car originally. WDB1240361B744547.
Photos are attached below. The car has various Lorinser bits - front and rear bumpers, exhaust backbox, speedo, steering wheel, gearknob, kick plates and 19" split alloys. Not sure how much is genuine but can't imagine there are many replica 500E specific parts made by Lorinser. The car also appears to have modified intake hoses but the engine looks reasonably clean.
I'm hoping to get it mechnically restored including full service (oils, filters, gearbox oil, diff oil), suspension and ARB bushes, spring replacement, new discs and pads etc.
I hope to add an ASR defeat switch, FGS module for traffic light grand prix and potentially Porsche 996 brakes (anyone know how to fit these). I will also be changing the front indicator lenses and side repeaters to orange.
I should be collecting in a week or two, but for now here are a few photos
500E's are quite rare in the UK but thanks to some car dealers importing a few over they are still for sale from time to time. I did see another E500 Limited (1995) from Japan in the UK however it was in real poor condition.
Comments welcome!
Bill
As of 16/08/2015:
- Full service (oil x4 (Shell Helix 10w40), oil filter x4, air filters x2, fuel filter replaced once)
- Fluids replaced - coolant, gearbox oil and filter and diff oil changed
- Plugs replaced with MB plugs on 28/03 at 172k
- Beru rotor arms replaced
- Beru ignition leads replaced x8
- MB engine intake hoses replaced x2
- MB headlight and windscreen wipers replaced (MB)
- Rear light lenses replaced with smoked facelift items (aftermarket)
- MB fuel pressure regulator replaced
- MB crankshaft breather hoses all replaced due to brittle cracking
- MB washer bottle & accessories (inc 1 new washer pump)
- MB SLS resevior and accessories replaced
- MB coolant resevior replaced
- Replaced bottom coolant hose (MB)
- Replaced shock mounts (MB)
- Replaced engine mounts (Lemforder)
- Replaced transmission mount (MB)
- Rainbow W124 front speakers fitted (rear wiring needs attention)
- Replaced number plates at MB dealer
- Replaced MB brake discs/pads/sensors all around
- Replaced MB aux resister for aux fans
- Replaced MB number plate lenses
- Replaced brake hoses with precision braided brake hoses
- Replaced coil leads x2
- Replaced serpentine belt (MB)
- Replaced serpentine belt tensioner
- Replaced distributor cap plastic covers x2
Various other bits and pieces replaced (oil cap, rubber parts, clips, bolts etc)
Things to do as of 16/08/2015:
Mechanical 2016
- Replace both fuel pumps and clips
- Replace propshaft boot bearing
- Replace distributor caps (MB/Bosch only)
- Replace distributor rear insulators (MB/Bosch only)
- Brake fluid flush and full bleed. Adjust metal hoses.
- Replace rocker cover gaskets (purchased)
- Replace prop donuts (1 purchased)
- Replace pollen filter
- Replace front and rear shock absorbers (Koni/Bilstein)
- Replace springs with H&R lowering kit (stiffer)
- Replace front and rear complete suspension bushes and arms
- Replace steering idler arm bushing
- Replace backbox hangers (purchased)
- Replace backbox nuts, bolts and gasket (purchased)
- Full wheel alignment/tracking (once the suspension is complete)
- Tint front and rear windows (rear full tint, front legal tint)
- ASR defeat wired in and centre console panel cut out (or place in speaker fader position)
Cosmetic 2016
- Full repaint in 744 Brilliant Silver along with door shuts and all panels off car
- Repaint door handles, grill insert, wiper arm and plastics, rear boot plastic handle and headlight wipers in satin black
- Replace boot seal (perished)
- Split and refurbish AMG/OZ 17" alloy wheels - silver painted centers and polished lips and bolts
- Replace upper and lower Ariel seals
- Replace sunroof seal
- Replace rear windscreen
- Replace fog light lenses x2
- Replace rubber wing mirror boots
- Replace window trims x4
- Replace pedals with MB sport metal pedals
- Fit fire extinguisher to drivers seat (purchased)
- Fit Lorinser rear spoiler and replace light bulbs
Cosmetic/Mechnical 2017 - future plans
- Fit Recaro C Classic black leather front seats
- Fit thicker rim steering wheel for better driving experience (Victor?)
- Replace front and rear entry door sills
- MB fridge fitted and wired in (due to lack of armrest with Recaro's)
- Alcantera headlining and pillars retrim
- Remove and steam clean carpets
- Re-wire audio throughout professionally and fit rear bench Rainbow speakers, upgrade subwoofer and amp
- Big brake kit front and rear (badly needed but serious expense so can wait unless something attractive comes up)
Comments welcome!
Bill
As of 16/08/2015:
Mechanical 2016
Cosmetic 2016
				 WDB1240361B744547_P9170053_zps4adaa3d0.jpg83.4 KB · Views: 29 WDB1240361B744547_P9170053_zps4adaa3d0.jpg83.4 KB · Views: 29
