Mine is custom built into the trunk space behind the rear driver wheel well (formerly wasted space), and the only real way I can tell it's there is the music.
Here's pics of my 15" sub install, courtesy of a PO:Any chance you could post up a photo?
Awhile back I fabricated custom door panels for 5.25" A/D/S coaxial speakers. I listen to lots of jazz and classical music, and love the characteristics of a single-point source for my music (minus the sub-woofer), hence the reason of custom fabrication. Completely Dynamatted the doors to do this, and had to run bi-amped 12-gauge wire.
Sounds wonderful and coherent, especially with the adjustable aim of the tweeters.
neil
<SNIP> Is that in a W124 coupe or sedan? If sedan, what did you do with your dash speakers (are they simply dormant)?
<SNIP>
The door speaker location would be poor for a midrange, but for the midbass use, there is not an issue. I'm sure you have already read what ERASE wrote here, with parametric EQ there should be no issue with the Jehnert driver location.\:- with 2 mid-basses of the jehnerts firing directly into the bottom of the seat is that really bad positioning that is going to soak up all that output? My audio guy wants to basically fabricate a set of doorboards that move the speaker forward (like what Neil did above in his set-up), could allow me to use higher end drivers as well (he likes hybrid audio).
If you have black interior, you don't have much choice. No other color is going to look better. I wouldn't worry about it. If there is any visual difference, nobody will notice except you, and you'll probably forget about it pretty quick after listening to the system.anyone done doorboards in black? My concern is that my 23 yr old door panels have the typical "sheen" that black gets having absorbed a bunch of product over the years and am worried that I won't get a great match to the rest of the door panel
I wouldn't remove the rear speakers entirely. They still provide a useful function as rear fill, and adding holes between trunk and cabin won't allow the bass frequencies to travel significantly better. If you want a trunk sub with massive cabin input you'd need 4th-order bandpass box that has the port exit into the cabin with no output into the trunk ($$$$$$$$ to do properly). My one car has Jehnerts up front, stock rears, sub in trunk, and it all sounds very good (IMO). I'm sure it could be better with a parametric EQ and ERASE tuning it though!my audio guy agreed 100% with gsxr that there are a lot better places to spend money than on rears, especially if doing something with as many drivers as the jehnerts and feeding them a boatload of power.....in fact he went a step further and is recommending that I remove my rears all together to enable sound from the trunk sub to more easily enter the cabin rather than going through gas tank / seats / rear wheel well and behind seats hushmat / etc. Obviously would keep the grilles in place so would just have the factory speaker opening without a driver
Get an external parametric EQ. No need for it to be built in to the head unit. I would recommend either going simple (4602 with everything else stock), or all the way (doorboards, external amps, sub optional depending on your bass needs). You may not be happy compromising in the middle.I am going to use a Becker 4602 for my head unit and a nice external amp (leaning towards arc audio) but the Becker doesn't have parametric eq or DSP capabilities; so with that handicap in mind am I kind of wasting money doing the jehnerts without better control? Should i explore getting some of that sound shaping ability through an external sound processor between the HU and amp (understanding that slope can get real slippery and very expensive)
The jehnert is better than stock setup but nothing to write home about. I went from that to a single 6.5" in the front of the door. 10 times better. Will post pics and more later.
I wouldn't remove the rear speakers entirely. They still provide a useful function as rear fill, and adding holes between trunk and cabin won't allow the bass frequencies to travel significantly better:
No - on my cars with aftermarket amps, all channels are run via the amps, nothing off deck power. I have Jehnerts in two cars, both have all speakers driven from older Soundstream Reference power amps, with Nakamichi CD-700 head units.in your setups do you just run the rears off the HU? Thinking these have nowhere near the power handling capability for amount of juice I would need to push to fronts (especially if went 3-way) and would like to get away with doing a 4channel Amp where rear two run the sub and front two run my front stage
Last advice is you have to be careful with "audio guys" who don't know the peculiarities of this car (tank like construction, OEM specs and fitments, wiring, etc.) giving you advice. What I have found is I come out better listening to the guys who know the car inside and out, then telling the audio guys what to do armed with that info, than asking the "barber" what to do about my "hair". That's just experience talking.
This car is a tricky one to get right from an audio and aesthetics standpoint. And the car is a matter of first impression to the audio guy, whereas some of the guys on this site are decades long 500E owners AND decades long audiophiles.
It makes a difference. So you're asking the right people.
It's a lot of work to do properly... the wiring should be routed in the factory wire trays, which means pulling a good chunk of the interior out (see photo below). No, you don't have to do this, and most shops wouldn't due to cost of labor. But basically you need to figure out where the amp will be installed, then run RCA's from the head unit to amp(s), and wires from the amp(s) to the crossovers, and from crossovers to each speaker. And you have to figure out where to hide the two crossovers - I put one under the rear seat, another under the front passenger footwell.How do you wire up the Jehnert speakers. I see two woofers (in the door panels), a mid in the dash, and a tweeter in the dash. What is the right amp setup to drive these?
So I bought the Jehnert doorboard kit. Paid $925 for it from Don Amman at Unexpected Creations. Good guy to work with and very knowledgeable....and sells all kinds of car audio equipment. Anyway, when I told Don that I had parchment interior with code 275 in my 1994 w124...yea, you guessed it. Confusion all over the place. So Jehnert sent me two color samples from Germany. One is a genuine leather Daimler-pergament and the other is a vinyl Kiesel-biege. It was interesting that they didn't offer genuine leather samples in both colors and then also vinyl samples in both colors. Turns out that the vinyl Kiesel-biege is a better color match...so I went with it. Photo below, sample on the left is the vinyl, on the right is the leather.
Roger, thanks.WARNING: Greg (8899)'s car is 1994 and Parchment. Jlaa, your car is 1993 and cream-beige. Slightly different.
I also picked up a set ScanSpeak Revelator 12M/4631-G00 4.5" mid-range drivers to go into the dash. These will be used instead of the dash mid-range drivers that come in the Jehnert kit. I got them super cheap off of eBay (slightly used but bought earlier this year).
<link deleted as it no longer works>
Btw, I will be looking to off-load the Jehnert dash mid-range drivers sometime in the near future just in case anyone is interested. According Don at Unexpected Creations, the Jehnert dash drivers are better than the dash Rainbows (which he sells as well).
Difficult thread to follow, but I think [ERASE @ BanzWorld] did use the Jehnert tweeters up front along with the ScanSpeak drivers:
I took the Jehnerts and jammed them as far forward as possible towards the start of the windshield.
Most car audio buffs will tell you to try to avoid early reflections... particular 5 ms RELECTIONS as they smear the sound stage and cause all sorts of issues when they combine and compete with the DIRECT sound..In fact our brains block/erase the second sound reflections (this takes lots of brain audio processing power...every wonder why your head hurts after being in a loud restaurant or starbucks for 2 hours?)
So short term reflections cause listener fatigue when combined with the direct sound. I noticed that the “premium� stock system in our 1994- 1995 w124’s was not really fatiguing but just wasn’t perfect sounding.. but the fact that it was not fatiguing gave me a clue.
So in an effect to eliminate the time delays associated with tweeter’s (as Jehnert gives you tweeters to install- our original drivers had a whizzer cone) I decided…. Since I can not eliminate the reflected sound completely (5 milliseconds means nothing can be reflected until after 5 FEET!) I decided… since here was not much attenuation from glass reflection….. to eliminated one of the sources of the time differences… My solution.. was to eliminate the DIRECT sound as much as possible and try to make it ALL RELECTIVE SOUND. I am happy to say that this strategy has worked better than expected.. making it all sound like direct sound without reflection. Pretty damn cool!
I jammed the tweeters to be as close to where the front windshieldmeets the glass and used “blu-tack� poster putty (never hardens or melts in the sun) to mold around the tweeter to make it flush with the dash and fill in around that. This also dampens the vibrations caused by the Midrange driver. It cuts down on sound diffraction too ..(The enemy of good sound) So the windshield now acts as an acoustic lens extension. The putty really helped make this work..and my sound stage is as taller than the top of the windshield and goes much wider than the boundaries of the car!
It's just hard to tell if he fit both the tweeter and driver under the dash speaker grill similar to what GSXR did.
I also picked up a set ScanSpeak Revelator 12M/4631-G00 4.5" mid-range drivers to go into the dash. These will be used instead of the dash mid-range drivers that come in the Jehnert kit. I got them super cheap off of eBay (slightly used but bought earlier this year). These here:
ScanSpeak Revelator 12M/4631G 4.5" Midrange
I'd try to copy ERASE's setup. I'd have to re-read his thread to figure out if he used the Jehnert tweeter, a different tweeter, or left out the tweeter completely. My only concern is the relatively lower power handling of the ScanSpeak (40w).
