Automatic tranny - torque converter bolt broke
koksmen
E500E Newbie
New Member
Hi All
what would be consequences of attaching torque converter with 5 instead 6 bolts? would it be of balance? or it will have no impact at all?
as i have almost impossible to remove broke bolt in one of that mounting points...
thanks !
Re: automatic Tranny
I would personally make an effort to drill & extract the broken bolt out of the torque converter mounting hole (especially if attached to a V8 engine flywheel), thereby eliminating any thoughts of consequence regarding rotating machinery under load.
+1. If you need to, remove the transmission (and torque converter) to extract the broken bolt.
Compromising this vital linkage between the engine and transmission isn't wise.
You should be able to extract the torque converter bolt through the window in the oil pan, where they are installed / removed. Might need to use a right-angle drill attachment, and/or remove some parts for better access, but I'd think it's doable.
That said, I don't think it's the end of the world if you have 5 bolts properly installed & torqued, but I'd avoid trips to the redline and wouldn't advice racing the car. You never mentioned if the car in question is a 500E, btw...
i'm sorry the cars is '90 300-24v m104
Thank You for your comments Guys. I have tranny removed. the problem was that one of the bolts was broken. after welding nut to it the thing become one as you can see now i have a problem to drill it even with cobalt drill
the only way now that i can see is to remove (flywheel) bolt it to torque and use it as a guide for drill. and use tap (taper) to recreate helix. (sorry for my english)
I have often used a Dremel with hardened steel tool like Dremel partnumber 9903, 9905 or 9910. Easy to get through the hardened metal to make a good center for a drill bit to grab. Also a left handed drill bit is a smart move.
It's good that you have transmission removed. If I was you, I would just use the hardest drill bit I could find of a large diameter and drill as much of that bolt out as possible, then use other tools to extract what is left. I had to do this not too long ago with an aluminum block drain bolt for an inline-six M104 engine. It was not pretty, and of all the automotive jobs I've ever done, it was probably the one where I came closest to having to actually call in a professional to help. Fortunately with persistence I was able to complete the job.
As an alternative: perhaps "soak" the bolt with a penetrating solvent (we have Kroil and PB Blaster here in the US for this) for a day or at least a few hours. Then use your left-hand bit to try to turn the bolt out.
The best thing you can do is have patience, perseverance/persistence, and don't rush it. If you find your level of frustration is getting high, then stop for the day and pick up the job later on.
Not to sound like a hack mechanic, but it will be fine.
A broken flex plate bolt is not really a big deal. If it really bothers you, buy a new converter. They are semi expendable anyway.
Now a broken pressure plate bolt is an absolute no-no. I had to fix another mechanics mistake on that one. Cost a customer a transmission.
Ok so i've manage to center flyweel and converter on the car.
upload png
now i need to find. bench drill...
this is engine side of tranny for 303 000 KM it's not bad but entire housing was covered with oil and sand. due to (as i think) head gasket... now engine is a bit of an back angle due to lack of tranny and i see a major oil leak. :(
image upload
the car itself
free photo upload
and my working post. ;/
