Yep. Should be sealed, and dry. A small amount of leakage, where the package shows signs of oil, may not be an issue... but if the clutch itself is wet, that's bad.Hi, I ordered an AVA unit and it has just arrived. The packageis oily. The clutch should be completely sealed, right? No plugs, caps or anything like that, correct?
I think it's too much but you guys can tell better.
I agree... that does not look good. I would return / exchange it. Preferably for an ACM brand; I've never heard of Ava?That looks burst to me- too much oil. Maybe it was sent by airmail - if there were any defects the change in pressure would sure make it leak
oh yea.....Looooong gone.
Is there a consensus about the rate of properly calibrated Sachs/Horton units? Is it still common for new units to be defective out of the box?
Guys is there any alternative to the meyle or graf water pumps? I have read bad things about both...
Also is ACM the best fan clutch aside from the dealer's one?
I'd spring for the OE/dealer rebuilt water pump. I'm suspicious of the $70 price on the Graf, and I don't trust the Meyle (at $100) any further than I could throw it. If I had to gamble I'd rather try Graf. ECS has a Geba unit which I'm not familiar with. The dealer pump is only $210 plus core charge from Naperville, free shipping:Guys is there any alternative to the meyle or graf water pumps? I have read bad things about both...
Febi is a reboxer- did it have a company name on the clutch?
The only ones thick like OE are the OE/OEM, Sachs or Horton.Didn't see any. It's thinner than the Sachs for sure. Kind of ACM looking.
All the thinner ones which require the shorter bolt are aftermarket (ACM, Vemo, or various no-name Chinese clones).
You may want to go back to post #20 at the beginning of this thread, and check out the photos...
I thought the 103 and 104 shared the same clutch - no? Pretty sure the engagement would be the same, somewhere between 85-100C coolant temp, in warm ambients.
I'd take a rebuilt OE clutch any day over aftermarket, but before you get too excited, call the dealer and see if it's actually available.
The thread is standard and loosens counter clockwise. Have a helper put additional preasure on the belt if possible. A soft wedge between pully and belt may also work.
If you can still find an ACM clutch, that is the low-cost fix for the fan. I'm only seeing ACM at ECStuning and FCP, and the photos look different than the ACM I bought years ago:
https://www.ecstuning.com/b-acm-parts/cooling-fan-clutch/1192000122~acm/
https://www.fcpeuro.com/products/mercedes-engine-cooling-fan-clutch-400e-500e-e420-e500-1192000122
The M104 as used in the W124 (104.99X) does use the M103 viscous fan clutch mentioned above -- 103 200 04 22 [XX]. That is the generally accepted part number for the M104.
Per the EPC, the 104 200 01 22 fan clutch is specified only for the 104.941 and some .942 engines (appears to be for W202 applications), as well as on the .992 engines up to 002496. So, it looks like it will also work in some limited 124 applications.
I would recommend always using the 103 part, and going with either Behr (aftermarket) or MB (new or rebuilt), for a 104.99X application.
I am actually using an M103 fan clutch on my G-wagen's M104 engine, as well, although it's a slightly different part number 103 200 11 22, which is specific to the M104 (G320) and M103 (300GE) based G-wagens. G-wagen fan-clutch HOW-TO is here: https://www.500eboard.com/forums/showthread.php?t=6152
That fan clutch wrench is not correct for the M119.97x cars. ...
Indeed not the right tool, found out first hand early this year. I ended up modifying it and grinding down the thickness for it work, final result was this (I was in a pinch, and neeeeeeded it to work):The C-shaped tool with 3 holes DOES NOT WORK on the W124 chassis with M119 engine (400E/500E, E420/E500). That tool is for different engine/chassis combinations. There's an old thread on this forum where someone tried to use this and found it simply does not fit between the clutch & pulley...
You got me here! I didn't think about rotation at all... Maybe someone with M104 can chime in here? If I ever go that route I will definitely replace the whole set - fan + clutch. My current aftermarket clutch is skinny already, I have no idea what brand PO installed but I have no doubts it is a cheap Chinese knock off.I have no firsthand experience, but first make sure the M104 clutch+fan rotates in the same direction.
Saying "reasonable" I mean 2-3 times more than other aftermarket clutches. It costs pretty much the same ($130) as ACM in US.Also, the Behr/Hella branded clutches that are inexpensive are very likely made in China.
On R129 M104 the fan rotates counterclockwise as you facing the motor:You got me here! I didn't think about rotation at all... Maybe someone with M104 can chime in here? ...
Hello Guest !
