Cool. You do you. I’m here to learn, not criticize!Just something to consider ... the energy stored in a spring is not linear wrt it’s compression. The energy stored in a spring is proportional to the SQUARE of the amount of compression. At 80% decompression, there may still be a lot of energy stored in a spring.
The spring cant travel anywhere. Even if the spring wants to burst outward instead of downward it cant. As the jack is slowly being lowered theres less resistance from the bottom of the spring. The spring will push in the direction it can and in this case thats downward because nothing is resisting it. You are releasing the pressure for it. Remember, when the car is raised on floor jacks and the wheels are in the air, the suspension travels down already decompressing the spring significantly. All you need is another few inches to get into the safe zone. Take apart a pen and grab the tiny spring from inside of it and put it between your fingers. Keep one finger stiff in place and move the other one down, pay attention how the spring is behaving. Play with it and itll be clear. Its basically the same principle.
When you are compressing the spring, you are pulling it out into open space out of whats holding it in and on top of that you are compressing it probably more than it ever gets compressed on the car. You are fawked if anything goes wrong with your tool especially using cheap ebay stuff.
Again, im not advising you to do any of this. It just seems you are already having a really hard time and are risking getting injured just as much.
Joe, I've had baaaad experiences with these external compressors. For one, I've had them slip around during compression, so both are next to each other! One just started slipping and BAM it was on the otherside. This was 15+ years ago on a VW spring, not a W124.If you want a less ideal but much safer setup just use a pair of regular external spring compressors!! The internal jobbie is not 100% essential. It should be faster and more convenient but seriously - the design of the plates is a little crap. There should be more arc / depth in them. Regular spring compressors do get a positive grip that wont let go. I might glue anti slip tool roll into my compressor cups for the next use and see if that prevents the skipping. That and improving the depth of the lug on the central shaft as that has also failed before.
Regular and IMO safer spring compressors-
Yes these do work on a w124 I used them successfully for years prior to getting an internal compressor. They are tricker to setup but it can be done. The internal compressor is simply quicker to setup and use.
You are more than welcome to borrow my compressor, my travel/availability is rather limited due to the work schedule. I'm going to be in Garrisonville/Aquia, exit 143 tomorrow for work. Can meet you around 4pm if that works for you... then I have to be in Frederickbsurg at the MB dealership before 5pm... I can meet you again to pick it up at Aquia again on Thursday to save to the extra miles.
D
TXT me arond 1 pm, 540-845-6615, and if you are going to make it, bring a spring with you and the ratchet for the demo ...Let's, preliminary, try. I'll send you a PM around 1 pm if I can make it. I should be, but just in case. Thanks!
Also, if you don't get industrial-grade versions, the shafts can bend... be careful if attempting to use these external versions!!
Photos are from 2004 or 2005...
View attachment 101655 View attachment 101656
I have seen those strip the threads halfway thru the job....scary.
Is there any reason you are tightening the compression tool from below and not from the top? It looks to me that you are doing this upside down. Approach the nut from the top side, reorient things 180 degrees if you are doing it from below.
Please review HOW-TO for W124.I had a look at the E500 engine bay and see that access from below (and section 32) show accordingly. This is not the case from my reference point, thus the innocent question. I have been so informed.
Here, you can see the shaft is already peering above the top 3-pont interlock. At this point turning bolt is an 1-1.5 inches inside control arm (need extension) to reach it. Yet spring has not yet began to compress. I can still wiggle the compressor. At other times it will start biting and compress almost right away...
. Once I knew 100% why the snaps happened and what the correct way was - two tools can't be both bad - paranoia stopped and I did R&R of the front driver spring in about 25 min
So basically it was compressing the spring temporarily by catching on the LCA (untill that lower edge of the shaft cleared the opening) and lifting the LCA upwards? Huh, ok!
I would take a pry bar (while the spring has some tension, and try get that plate sited properly!
I agree with Duh, pry that spring on to the lower plate before you compress further.
If you loop a tow chain through the spring as well as the top perch and lower control arm
I'm concerned that there is only a tiny portion (circled in blue) of the lowest coil that is propping up whole spring and prying another coil above it might(?) cause it to pop out. You guys have 15 tons of experience, does my concern have any grounds to it? Is whacking it with a hammer back towards the perch in the LCA a dumb idea?
Drew, could you please be a tad more specific as to the type, size, end-connectors, etc.? I'm not familiar with towing chains at all... Thanks
Does this car not have double wishbone sispension?
I dont know why you ever wanted to use the spring compressor at all if it was as simple as just dropping the shock
Almost every Mercedes passenger car made since the mid-80's continued to use the same 5-link rear suspension design, well into the 2000's. 202, 203, 208, 210, 170, 171, all had the same layout and shared almost all part numbers. IIRC, even the 140 was the same design, just with larger components?The rear suspension between the W124 and the W202 is much more similar, if I remember correctly.
Yeah! That's it. Funky was being kind.Old-school funky rear suspension was properly called trailing-arm rear suspension. It was introduced with the W115/114 and W116.
Obviously you're not familiar with the swing-axle rear suspension that MB used from the 1950s through 1972.
@LWB250: I'm just mean enough, that if they weren't so expensive and rare, I'd get @gsxr a W112 or W109 with leaky air-ride valves and iffy Phönix airbags, and let him have fun with diagnosing and repairing the swing-axle + air suspension. He'd be lovingly wishing for a "simple" 240D with its trailing-arm rear suspension by the end of it......
