HOW-TO: Replace Early W463 Headlight Switch
Site Honcho
Early W463 G-wagen models, from 1990 through about 2000, share their headlight switches with MB sedan models such as the W124, 202, and so forth. This is the standard round switch with the pull-off knob, foglight indicator light in the center, and so forth.
With age and sometimes use, these switches can go bad as the plastic inside that forms the detents gets brittle and cracks, resulting in an inoperable/mushy switch that rotates in a notchy manner, or not at all.
I noticed late this past winter that my G-wagen's headlight switch was starting to lose the crispness of its detents when I moved it from mode to mode. It still worked fine, but it was notchy and at times a bit difficult to move.
New/replacement switches are not that expensive to buy new, and are certainly available from MB and the usual aftermarket discount houses, but I happened to have a spare or two in my parts stock, and a quick check of the EPC showed the G-wagen part number (for my truck, at least) was the same as the switches that I had in my parts stock. The one that I located came from an early W202 model.
Below is the procedure for replacing the headlight switch. It can be accessed either from above or below. From above, on the early G-wagens, it can be removed through the top-dashboard speaker hole. From below, one must remove the driver's side dashboard vent and then access the switch by reaching upward through the vent hole.
I decided to access the switch from above. Below is the procedure to do this. The job takes approximately 20 minutes to complete.
TOOLS REQUIRED:
  • Philips screwdriver, medium, stubby preferred
  • Medium pair of pliers
  • MB instrument cluster removal hook (or homemade equivalent)
MB HEADLIGHT SWITCH PART NUMBER: 000 545 60 04
The first step is to take a deep breath and get a visual overview of the area you'll be working in. Since it's up close to the nearly vertical windshield, quarters are a bit tight, but shouldn't be a problem.
Here are a couple of views of the driver's side dashboard area where the headlight switch is located:
The first step is to remove the knob. It comes off with a stout pull directly outward:
Next, after removing the knob, use your pliers to loosen the retaining nut, which is on the shaft of the headlight switch. After loosening it, you can remove it with your fingers. Also, be sure to remove (and don't mis-place) the round washer behind the retaining nut.
The next step is to remove the headlight switch bezel. It just pulls straight off after you remove the retaining nut and washer.
From there, you need to remove the left-hand trim piece directly underneath the windshield. This is held to the top of the dashboard by two plastic expansion pins -- one pin at each end. Use a Mercedes instrument cluster removal hook on the slot at each end of the trim strip, pulling straight upward to pop the pin out of its socket. You can see the process below. Start with the side of the trim strip that is closest to the driver's side door; then pop the right end (center of the dashboard) upward with the tool. (In my case, I needed to remove the gray-market G-wagen VIN tag, which was affixed to the top of the trim strip).
Here are a couple of views of the retaining pins.
Note that the right-hand end of the trim strip has a tab that extends 1-2 mm from the end of the strip. This must be inserted UNDERNEATH the right-hand dashboard trim strip -- an important thing to do upon re-assembly.
After removing the trip strip up and off of the dashboard, the next step is to remove the speaker grill. It is held onto the top of the dashboard by a single Philips head screw, and two plastic tabs on the underside of the grill that slide into slots in the top of the dash.
Remove the single Philips head screw, and carefully lift the grill off of the dashboard, as shown below.
Note the small hole for the side window defroster vent, in the edge of the dashboard.
Removing the speaker grill exposes the speaker. Remove it by unfastening it from the dashboard, and lift it out of the way so that it is not in your work area. My aftermarket MB Quart tweeter had enough wiring that I could just move it to the top of the dashboard, as shown.
This is what the switch looks like once the bezel is removed.
Rotate the switch in its holder, so that the two tabs are free, and then carefully push the switch backward toward the front of the truck. Lift it vertically straight out of the speaker hole, as shown below.
After the switch is clear of the dash, CAREFULLY unplug and separate the large round plug from the rear of the switch.
Here are a couple of views of the old and new switches, side by side. They are identical in every respect except for a burned-in four-digit number on the side plastic.
Installation is exactly the reverse of removal.
Enjoy your new, working headlight switch!
:gwag:
Following up on this HOW-TO, I did a post-mortem dissection on the old G-wagen headlight switch. Remember, this is a nearly identical switch that is used on our E500Es, as well as other 202 and mid to late 1990s passenger car models.
You can see the typical degradation of the interior plastic detents that the headlight switch rotates into for its different settings.
The plastic was old and brittle; and the lubrication was also pretty gummy (although present).
The lesson to all owners here, is that if your headlight switch gets notchy, difficult to turn, or sounds/feels different (lacking the firm "click" when you go from detent to detent), it probably is in this condition, requires replacement. Don't wait -- get a spare/replacement as soon as you can. As I mentioned, they are not that expensive. Current MB list $102; available ~$75 discounted for the G-wagen switch, part number 000 545 60 04.
The E500E (W124) switch is part number 000 545 62 04, MB list $83; available ~$65 discounted.
Who is the OEM for the headlight switch widely used in the early W202, W463, all W124s, and etc.???
Recently did this on C126, don't forget the ignition switch is not a bad item to buy as well for the shelf. 25-30 years is plenty of time to consider changing it out of an abundance of caution. :shocking:
Right. But I'm trying to find out the manufacturer of the headlight switch. The switch is $62.16 on mboemparts.com but also plenty of options for this part (000-545-62-04) on eBay. If I can find an OE switch on eBay for less from a reputable seller, I will get it there. Thanks.
Understood. My experience is to pay up for the MB product as they are not all the same. Alas, I understand the dance between wallet and obsession :D
AFAIK, the OE/dealer switch is the only game in town. $62 delivered is not a bad deal. Note that reputable aftermarket vendors (FCP, Importec, AHAZ) only offer OE, Meyle, or URO. Anything on eBay is going to be the same.
I've tried used switches in the past but they ended up failing within a year or two. Now I just fork over the sixty bucks for new.
I used a very lightly used switch from a W202 car that had low miles on it, which I got from a wrecking yard. Fortunately, it was the same part that my G-wagen used. I do intend to purchase a new switch to have on hand, for the inevitable day that comes when the "used" switch dies.
Just used this guide to change the switch in my 99 G500 and it was very useful. The tips on removing the top vent cover were helpful as those tabs looked like they could break very easily!
Thank you!
TOOLS REQUIRED:
View attachment 69176 View attachment 69178 View attachment 69177
View attachment 69179 View attachment 69180
View attachment 69181 View attachment 69182 View attachment 69183 View attachment 69184
View attachment 69185 View attachment 69186
View attachment 69187 View attachment 69188 View attachment 69189 View attachment 69190
View attachment 69209 View attachment 69210 View attachment 69211 View attachment 69212
View attachment 69192 View attachment 69193 View attachment 69194 View attachment 69195
View attachment 69201 View attachment 69202
View attachment 69198 View attachment 69199 View attachment 69200
View attachment 69205 View attachment 69206 View attachment 69207 View attachment 69208
:gwag:
Gerry,
Great info. Question, I have a buddy who just purchased a Japanese import g320. We're curious what the additional headlight switch is for? Below the actually headlight switch and to the right, nearly shadowed by the 7 O'Clock part of the steering wheel.
Can you send a photo of what you're referring to?
It may be the wheel for adjusting the headlight height (non-US models allow the headlights' aim to be raised or lowered, for example if towing a trailer and the height of the vehicle is altered),
Yep, that's for adjusting headlight height, depending on the load in the vehicle and how the vehicle is angling.
Thanks for another great writeup. We'll make use of the above on the G320 this weekend after parts arrived today :)
Any idea of the bulb ID by chance?
Thanks again,
James
TOOLS REQUIRED:
:gwag:
Bravo Gerry!!!!!
Your writeup here is second to none. Thanks a million for sharing your wealth of knowledge. I will be embarking on this as soon as I get my new Switch in hand.
