That information is accurate. On a non-ASR car, the throttle body should open fully with the pedal pushed to the floor. You've verified this, correct? As mentioned in posts #12 and #16 above?I am up early in the morning doing research and I read this on another forum ............"That is correct. The throttle body on non ASR vehicles only controls idle and cruise control function. This cleaning will not help with acceleration issues"
This is interesting.Just getting ready for my last option if the upper engine harness dont fix.Guys , where can I find the correct engine range for the correct throttle body?Not interested in rebuilding if it's bad.
@sheward knows what he is talking about! Don't listen to banzworld How Do You Clean Your Throttle Body | Mercedes-Benz Forumhttps://www.benzworld.org › ... › W140 S-Class !!!You are getting incorrect information. Listen to the folks here.
Your question about engine range is unclear. You are going to need a blink code reader if you want to solve your issues.
No, there is nothing warning . Don't have ASR ..I recieve my code reader tomorrow . If the cats are bad , do you think a code will be stored?The ETA has either been rebuilt or replaced, there's a tamper seal which isn't factory. Photo isn't clear enough to see the date code but it looks to be old/original, not a newer date code. Again, with a non-ASR ETA, this is less critical because the throttle plate opens all the way when you press on the pedal (assuming the throttle cable is properly adjusted).
If the wires are good at the injectors, and also at the cam advance solenoids & temp sensors at the front of the intake, the harness may be ok as well.
Free test for cats is to remove the exhaust crossover pipe below the engine and go for a noisy test drive. Otherwise you can use an exhaust backpressure gauge.
Any warning lights on the instrument cluster, btw? Can't recall if you've mentioned that
Thx for all your help . You mean the insulators on the parts car ? I never took them off .I just cleaned mine . For all your help and advice , you are welcome to come take stuff off the ASR car . You can come get that throttle body . I plan on stripping in about 2 months months .Glad you are making progress. You did not waste money on the ignition parts. The caps were bad and were soon to be a problem. If you feel you would like to put the money spent on the insulators into something else I will buy them from you. Most everyone here will advise you stay with new. It's hard to judge the condition of insulators even with clear pictures.
Catalyst plugging is not a binary thing, it's analog. Catalysts can allow revving up the car in park (no load) but restrict power when driving. The tests I described above are the valid test, not whether it will rev or not. I don't know if there will be any temperature difference if plugged..A muffler shop tells me , if the cats were clogged I wouldnt be able to rev up the car.
Plugged cats can also cause low vacuum which would cause a harsh shift. There is no "limp mode", this is a completely mechanical transmission.This must have something to do with the harsh shift anbd vacuum. Maybe the tranny put the car in limp mode.......my guess.I recieved the code reader in the mail.I will read the manual tonight and scan it tomorrow
Do you see the attachment ? For example pin #7 , I had two blinks and then the next test I had three blinks ......2,3Sorry , I just wrote # 5 down , my bad
are the codes I am getting before I cleared the ECU . For example pin #5 had no codes . Pin # 19 had code 7, 20 and 25.
Disregard the 25 written on the far Bottom .
Please see attached . I couldn't reset some terminals with the code reader . The reset that worked was the DTC reset button .
Since I just reset , I will drive around and rescan tomorrow
There is no attachment to your post, can you try again?
There is no module connected to pin #5. What code document are you using?
Pin #19 (DM) codes indicate ignition issues. As described in the instructions in the document I referenced previously, not all systems have blink codes available, but all the powertrain modules will have blink codes.
Great. ThxCool! With everything clear, see which codes return immediately and focus on those.
You particularly want to look at what shows up for pin 4 (fuel), 7 (idle speed control), and 17 (ignition).
I am posting before and after codes clearedCool! With everything clear, see which codes return immediately and focus on those.
Yes, the serpentine belt is slipping causing noise on start up.The previous owner replace the tensioner and it still squeals , but this is only when cold.All noises goes away when warmed.I am thinking a pully other than the tensioner is causing this.Pin 8: Check all fuses on the BM/GM module in the CAN box. You also may have issues with either the serpentine belt slipping, or the AC compressor speed signal.
Pin 17: This is a hot mess, if you got all those codes AFTER clearing. You are sure Pin 17 was cleared, right? Make sure the knock sensors are plugged into the EZL (code 5), that is the 3-pin connector at the EZL. Ignore code 8 and 18 for now.
The last codes on pin 17 indicate a permanent misfire on cylinders 1, 4, 6, 7. These are all from the passenger distributor. The car would run terribly if these four cylinders were misfiring all the time. You said it was not misfiring... so either it *is* misfiring and you don't realize how smooth the engine should be, or the codes were not fully cleared. Clear all those codes again and make sure you get ONE BLINK from pin 17 before starting the car again.
Gotcha!Will clear again , and rescan.Pin 8: Check all fuses on the BM/GM module in the CAN box. You also may have issues with either the serpentine belt slipping, or the AC compressor speed signal.
Gotcha. Ac doesnt even work.Freon is leaking and probably low He said he changed the compressor and Ac was working.I havnt gotten there yet, since this was minor to me.Make sure the serpentine belt is the correct length. The tensioners almost never fail. I hope the PO didn't install a junk aftermarket tensioner. Also try to figure out which specific pulley is causing the squealing. If you shut off AC does the noise stop?
The hand-held coder reader MUST be used to clear each individual code, one at a time, on each pin. Takes forever. Sounds like you may not have fully cleared everything. After clearing you should read ONE BLINK on each module. If not, repeat until you get ONE BLINK. The "diag reset" button you mention is only connected to pin 19 and does the same thing as if you had the code reader plugged into pin 19. The codes on pin 19 may not fully clear until after you re-start the engine, this is normal.
A bit tedious but I was able to clear each pin using the reader . Yes, pin 19 was the hardest . Cleared and drove for about 10 miles . Do you see the loose wires coming from under the EZL ?Make sure the serpentine belt is the correct length. The tensioners almost never fail. I hope the PO didn't install a junk aftermarket tensioner. Also try to figure out which specific pulley is causing the squealing. If you shut off AC does the noise stop?
Ok.Will do tomorrowIf you cleared everything and STILL get codes 34, 36, 38, 40 on pin 17... the car must be running on 4 cylinders.
Can you upload a video to YouTube and post a link here? Sample M119 cold start below (ignore the rattle noise).
I am looking at the distributor routing diag and it leads me towards the passenger side plug/wires/distributor and coil.If you cleared everything and STILL get codes 34, 36, 38, 40 on pin 17... the car must be running on 4 cylinders.
^^^...codes 34, 36, 38, 40 on pin 17 indicate a permanent misfire on cylinders 1, 4, 6, 7. These are all from the passenger distributor.
I just changed the EZL from the parts car.I will trace the wires going to the passenger coil.Either a bad coil, or a bad EZL.
Yes, that was the irony that confused me . No sign of a miss , engine vibration etc ........except driveability . I just learned something about these carsIt sounds OK in the first video, but if you can unplug a coil and there's no difference...!!!
One more thing , I forgot to include a video of the unplugged coil for the driver's side on idle . There was definite miss and a spark from the coil .It sounds OK in the first video, but if you can unplug a coil and there's no difference...!!!
Yes, solved . Thanks to you and gsx and few others . Yes, the coil that leads to the passenger side distributor was bad ..The previous had no covers on them . I grabbed the one from the parts car . This $700 car needs a lot of work , including a paint job . Looks like he lowered the car . I am not into the wheels or lowered cars . I have a huge project . Let me know you're coming down south . Thx againDid you solve the problem? Was it the coil?
The car looks nice, btw. Those are nice wheels on a W140.
Great . Keep me postedGreat. I can take no credit as, other than resolving some secondary ignition problems with my own cars, my drivability knowledge is academic and comes from reading this forum.
I'll follow up in the near future on the ASR parts car.
I know of another S420 parts car 1.5 hrs. north of here. I have been in touch with the owner and will let you know if it's a non ASR car and what might be available.
Hello Guest !
