Lately when I go to start my 95 E320, after a period of being parked for hours, I get an initial high idle that lasts for less than a second. When I switch the engine off and start again, the idle is normal. The car runs very well and the only issue is the startup.
I searched the internet and found this article
Has anyone had similar issues?
03/95-2 M104 WITH HFM INJECTION SYSTEM
In case of customer complaints of high idle (approximately >2200 rpm) for a very short period of time (< 1 second) immediately after cold start, an updated EA/Idle control unit is available from our PDCs. The updated control units can be identified by a software production date of "SW 43/94" and higher stamped on the housing in the area of the barcode label. The following control unit part numbers are affected:
Electronic Accelerator Control Units (E-GAS) Part No.
124 545 65 32 - E320
129 545 05 32 - SL320
140 545 49 32 - S320
202 545 01 32 - C280
Idle Control Units (T/LLR) Part No.
124 545 55 32 - E320
129 545 19 32 - SL320
140 545 52 32 - S320
202 545 43 32 - C280
