Size of small bolts around face of 3-pc OZ AMG wheel
Dik Best
Hello
I have just purchased set of Oz Amg but i can't find what type or size nut to remove multiple
bolts on the face of the wheels Can anyone help
Thanks Dik Best
Just order them online. It's not hard to find anyone and way cheaper vs 10 years ago
Jono (@jhodg5ck) do you find the aftermarket bolts to be as good as the factory? Also is that bolt common to all multi piece AMG wheels? That is, did AMG require subsequent suppliers (e.g., Cromodora v BBS) to use the same bolts?
I believe he was looking fr the tool to remove the bolts.
Btw in most cases those bolts are made out of tiatanium. Something to keep in mind if you need to replace them.
I have a custom set of sockets that fit the original OZ racing 3-piece AMG rim bolts. I used to have 3-4 sets of these wheels. I would open to selling these sockets. They are special 10-point sockets for the front/back of the rim bolt heads/nuts. I also have one full set of 35 fully restored rim bolts with the OZ and 10.9 markings on the bolt heads (for one wheel). Original nuts are re-plated as new. The bolt set won't be cheap, though, and Jono at Blue Ridge would have first chance at these.
Thanks everybody but my local tool shop have found that Laser tools make a
specific remover for Oz three piece rims its now on order
Thanks again Dik Best
Yes, Laser Tools 6345 is the right tool for these bolts:
I got my tool set from Pertsch & Partner:
Here is another set from Torque Parts:
And here is another thread with some info on the topic:
FYI, both Pertsch & Partner and Torque Parts have the proper rim bolts for these wheels.
As for Titanium bolts, well it sounds cool and give a marginal weight savings but cost arms & legs. So unless you plan to race the car and fight for the podium, use steel bolts and drop drinking one glas of water before driving and you're pretty much on par with that weight savings anyway.
:tigger:
While working on my rims, I came across information that Honda uses this specific bolt head on their minivan of all things. The upshot is that the sockets for the minivan crowd are readily available and less expensive. I initially bought the set of Laser tools, waited ages for them to arrive only to have it break on the third bolt. Searched around found the minivan alternative on amazon and they worked perfectly.
Minivan socket set alternative.
