im linking a youtube video of whats going on. I need the legend gsxr to help my bad situation
ill start by trying to get the error code funny thing is i dont get a check engine lightYo need to read faultcodes...hopefully there are some to use. IF not...you need to go by actual values. That idling has nothing to do with " poor distributor caps". It sounds more like either vacum leak, bad ignition module, or throttle body /wiring. Something is up for sure. And a faultcode readout/ actual value session is A must.
A check engine light only pertains to emissions-related faults, which is one of four or five different computer modules that the car has.ill start by trying to get the error code funny thing is i dont get a check engine light
its US specA check engine light only pertains to emissions-related faults, which is one of four or five different computer modules that the car has.
Does your car have a check engine light, because it is a US model?
You will need to read codes. There is 99.9 percent something wrong,that will show up to give you a direction to where to look furtherill start by trying to get the error code funny thing is i dont get a check engine light
where can i find that obd1 reader and im gonna change all the vacuum hoses. i had a look at them today they are fossilisedYou will need to read codes. There is 99.9 percent something wrong,that will show up to give you a direction to where to look further
There is no obd connector. You need a 38 pint connector,that connects to the connector located on the "CanBox " ,again located on the right uppers side of the engine bay.where can i find that obd1 reader and im gonna change all the vacuum hoses. i had a look at them today they are fossilised![]()
where can i buy a 38 pin connectorThere is no obd connector. You need a 38 pint connector,that connects to the connector located on the "CanBox " ,again located on the right uppers side of the engine bay.
you need to have a complete diagnostic system. If you dont..then you need to either get the car to a workshop..or find someone who can assist you,Its not about resetting codes..its about reading codes..so you can diagnose the problem/issue your car is having.where can i buy a 38 pin connector
There are four wires (one for each cylinder) that go from each distributor cap to the spark plugs on that cylinder bank. And then, there is a single wire in the center of each cap, that goes to one of the coils, which are located behind the driver's side headlight, under the tandem pump.whats the right number of wires from spark plug to caps can u send the diagram
also here is another video
#1 question: Was the car running normally before you replaced the caps?
If so, did you do ANYTHING else besides replace the caps?
it was just cranking not firing up
is there a way to reset codes without a readerAnd before you rip your wallet out TEST, the nicest 4 letter word you got. SMOKE test and find the problem there, if it exists first - then move about the other stuff. (clear codes too) then see where you are.
at 1.5k rpm it runs smoothIf the car was running perfectly before you replaced the caps (you never answered this question!) you need to figure out what you touched that caused this. Also - you could try reinstalling the old caps (only change 1 side at a time) to see if the problem goes away. I've seen defective new caps out of the box, it's rare, but it can happen.
Throttle body shouldn't cause the problem shown in the video, unless it's only an idle problem (and runs perfectly except with no throttle input). Disconnect the MAF temporarily to test if it's bad, if the engine runs great with the MAF disconnected, but terrible when connected, the MAF is likely bad.
Order new vacuum tubing from the dealer or an aftermarket parts vendors, it's 4mm OD / 1mm ID Tecalan. Details here.
PCV hoses, buy only from the dealer, the aftermarket stuff won't last. Part numbers here.
OK - did you just buy this car and it wouldn't start? Or had you been driving it, running normally, then after installing new caps it wouldn't start?it was just cranking not firing up
No, but this doesn't matter. Fault codes won't cause bad running. It will just keep all codes in memory until manually cleared.is there a way to reset codes without a reader
If running smoothly at higher RPM, firing on all 8 cylinders, your wire routing is good. However a defective cap can cause a misfire at idle (just not with the oscillation or engine shutoff seen in your video).at 1.5k rpm it runs smooth
In that video, at idle it sounds like 1 distributor or coil isn't firing (or, the EZL has failed). As noted in your video, you might also have 1 or more bad plugs, pull all 8 to inspect. Make sure they are non-resistor plugs, F8DC4 or equivalent.Here the video of me disconnecting it much improvements but still bit of miss fire when i say imporvements i mean the car doesnt kill itself.
Here is the video
ill update u on that , coil also ill have to only disconnect it from the caps rightCorrosion on the rotors won't cause a problem. 20kV blows right through it. You can scrape the contacts if it makes you feel better.
Check the plugs, and try disconnecting 1 coil or cap at a time, before thinking about the EZL.
Yup, doesn't matter which end of the coil wire you unplug. Probably easier to unplug at the cap.ill update u on that , coil also ill have to only disconnect it from the caps right
ill update you tomorrow gsxr i swear i dont know what ill do without thank youYup, doesn't matter which end of the coil wire you unplug. Probably easier to unplug at the cap.
i read the form tomorrow ill do it ima scream in german at this why did they place it there lolCOIL change is a maddening experience if you have hands bigger than a small child. Take the headlight out so you do not break anything else as you scream! Not that bad but sheesh this process, even with a analog blinker or a SDS clone system, its a PITA!!
Because there basically was no other place in the entire engine compartment to put the coils.i read the form tomorrow ill do it ima scream in german at this why did they place it there lol![]()
No that means the caps are good i cant lie the coil pack job has changed me i never had this much pain in my hands , my hands are numb from the cuts and 30 year old dust and oil on my hand here is the video of me removing it also where can i find a MAF sensor.any change with the old cap installed?
And a lot of those failure are from not putting the correct paste on the back of the EZL in my experience. Most do not even know to add the past or even why there is this discolored stuff on them. They short out.BTW - in over 20 years of M119 ownership, and at least a dozen different M119.97x vehicles, I've not once experienced an ignition coil failure. I'm not sure if anyone on the forum has reported coil failures either. The coils are robust and rarely fail.
EZL's, OTOH... there have been multiple reports of failed EZL's. It's not common though. I've never had an EZL failure on my personal vehicles.
Best bet is to change them and check also where can i find a 4.2L EZL.Replacing the coils with the headlight in place is a nightmare. You are right, we weren't joking!Just pull the headlight next time, it's SO much easier. Since you have them both out, install 2 new ones. They are not the same part number. Search the forum for part numbers & vendors. Get Bosch only. While the coils are disconnected, also measure the wire resistance (the wire from coil to cap). Make sure both wires are near zero ohms.
As mentioned previously, coil failures are quite rare. If you replace both coils and there's no change... it's pretty likely to be a failed EZL. Unfortunately it's not possible to easily test the EZL, if you don't have SDS, you'd need to borrow a good used EZL (must be from a 4.2L engine) to try out.
Smart move ditching the HID's. Look for quality LED bulbs that have an accurate light pattern (more info here).
MAF is the round thingy under the center of the airbox with the ripped metal screen. Yours isn't necessarily bad though. Can't test them without an SDS to view live data. MAF's are NLA, only option is to buy a used one and hope it's good.
Hello Guest !
