Hello everyone,
The car in question is a 1995 E500 with approximately 128,000 km on the odometer.
I come to you with a very annoying issue: the ASR light comes on as soon as I start up the engine and the revs at idle are limited to approx. 500 rpm. Additionally, pressing the acceleration pedal has no effect for approximately the first half of the pedal stroke, until I encounter increased physical resistance - the engine revs only if I push through that resistance. Please note that no other light in the dash comes on (including the ABS light, which I saw sometimes accompanies that ASR light).
I went to a mechanic and ran the STAR diagnostic tool on the engine and got multiple faults, as per the pictures attached. Now, the guy who ran the diagnostic tool is fairly certain that this is caused by a wiring harness malfunction (since this MY is known for its dubious biodegradable harnesses). However, from a previous check, I was able to confirm that the upper wiring harness (please see in attached pic) was replaced post-2011 with a Delphi component. The harness in question (where I was able to check that) is located in the upper left corner, next to the round diagnostic port. I was not able to verify whether the throttle body harness and the lower harness were indeed replaced as well.
My question to you guys is: since the upper wiring harness was replaced, do you also think that the throttle body harness is the main culprit for this? Or could it be something else?
Please don't hesitate to ask me for additional details which I may have skipped.
Thank you very much in advance!
