Agree with Gerry - Total Quartz 9000 5w40 (formerly Elf?) in my E500 200M+ 5000-6000 miles every 3-4 years
The best way to see what is happening with an engine, is to get an oil analysis after every oil change. I have done this for decades with all of my cars' engines.Maybe use a magnet to get any metal for a look to see whats happening in engine.
I've been running Brad Penn since 2010 in my 560SEC / M117, when I rebuilt the top end of that engine. It's still running just fine using the original catalytic converters that were shipped with the car in 1989. The car has 250K miles on the chassis, and 60+K on the rebuilt engine.If you run Brad Penn high zinc etc good for your cat? And what about smog chks? Is it full synth?
I had a 117 420 sec 87 and traded it for s5004dr 95I've been running Brad Penn since 2010 in my 560SEC / M117, when I rebuilt the top end of that engine. It's still running just fine using the original catalytic converters that were shipped with the car in 1989. The car has 250K miles on the chassis, and 60+K on the rebuilt engine.
Remember that "back in the day" these engines used dino-based oils that had an API spec with much higher levels of zinc and phosphorus and other chemicals than today's oils have. And these engines' catalytic converters weren't negatively affected.
It's only been the past 15-20 years as cats have evolved, that oils with less of those chemicals have been spec'd, and API ratings have spec'd less of these chemicals in the oils to reduce any ill effects on catalytic converters.
But, if you are using original spec cats, with oils that were in common use/spec at the time the cars were new, then I don't see any problems whatsoever.
At 500 to 1000 per year I tend to agree.Totally agree - no need for changing the oil every year. I just got another Blackstone oil sample test on my other car --- these are their comments (and I used Mobil 1 15W-50, which is a pretty pedestrian oil)
This is another great report for your car. Calendar time does not have a negative impact on oil. Ifyou went 100 miles in three years, the results should be the same as going 100 miles in one trip.Operational factors, like how the car is driven, have the most impact. We have no reason to suspect thatany mechanical issues are developing at 62,750 miles. Wear metals compare favorably to your baselinereport, just with a bit more mileage. There isn't any excess fuel or water, and the oil maintained the correctviscosity. The TBN is strong. Try 3,000 <between oil changes> miles next time!
How much and where to get it?The best way to see what is happening with an engine, is to get an oil analysis after every oil change. I have done this for decades with all of my cars' engines.
Magnetic drain plugs aren't a bad idea, but an oil analysis is going to be best.
Agreed.I'm going out on a limb here and say change your own oil at least 1 time per year no mater what the miles or brand.
Run the car before draining it.........
Then observe what you find in the bottom of the bucket ...
It's inexpensive and the life blood of your m119 engine
Probably stay the same or get sliiiightly worse. If the leak is from the side of the timing cover, you can add an external bead of RTV to reduce or possibly stop the leak entirely. Read this for details.If you have timing cover leaks and you go from semi synthetic 10 40 castrol high miles to full synth 10 40 redline would the existing leak get worse?
I would concur, exactly. It would depend 100% on the age, mileage and number of heat cycles that the existing (factory) timing cover sealant had experienced. On an engine with 100K miles or more, I would expect to see PERHAPS a slight amount of leakage at the timing cover. Though, perhaps no leakage as well. It's a bit of a crap-shoot.Probably stay the same or get sliiiightly worse. If the leak is from the side of the timing cover, you can add an external bead of RTV to reduce or possibly stop the leak entirely. Read this for details.
Yeah, Lexus recommends a 10K OCI for our 2024 LX600, using 0W-20 oil. F that. 5W-30 is also specified for this vehicle, for markets that are non-US, so that is what I will go with going forward. We had the oil changed (complimentary change for new vehicle) at 4K miles (6,500 on the truck now), and I will have it changed every 4K going forward.Speaking of what grade oil to use my knew to me 2024 Toyota Camry “Beater” w/18.8K on the clock specifies 0-16 grade oil on the filler cap. The dealer still owes me another service so I’ll be sticking with that grade for about 6K more miles. I’ve never even heard of 0-16 grade oil!
I have a 97 jeep grand cherokee LtdYeah, Lexus recommends a 10K OCI for our 2024 LX600, using 0W-20 oil. F that. 5W-30 is also specified for this vehicle, for markets that are non-US, so that is what I will go with going forward. We had the oil changed (complimentary change for new vehicle) at 4K miles (6,500 on the truck now), and I will have it changed every 4K going forward.
The Lexus dealership service advisor looked at me as if I was crazy, getting the oil changed at 4K, when they said it should be changed at 10K.
You did a how to thread on this before correct?Most newfangled oils these days tend to have some amount seal-swelling agents, to help with leakage from radial seals (e.g., front crank seal). However the timing cover has no seal nor gasket. Once the anaerobic liquid sealant has failed, nothing will "fix" that (besides the aforementioned external Band-Aid). Pulling the timing cover is nightmare fuel, and there's usually no need to ever remove this, which is why the external RTV is a convenient way to eliminate that particular leak if present.
Me either is that like baby oil? Probably flows quickly though!!Speaking of what grade oil to use my knew to me 2024 Toyota Camry “Beater” w/18.8K on the clock specifies 0-16 grade oil on the filler cap. The dealer still owes me another service so I’ll be sticking with that grade for about 6K more miles. I’ve never even heard of 0-16 grade
I agree with 5 30 as maybe 0 20 is absurd....crisco oil. 5 30 is the lowest I have used your euro info is insightful....I heard the lower the weight the lower the emissions?Yeah, Lexus recommends a 10K OCI for our 2024 LX600, using 0W-20 oil. F that. 5W-30 is also specified for this vehicle, for markets that are non-US, so that is what I will go with going forward. We had the oil changed (complimentary change for new vehicle) at 4K miles (6,500 on the truck now), and I will have it changed every 4K going forward.
Which oil do you recomend for a time cover seal leaker should I go back to 20 50 High miles?Most newfangled oils these days tend to have some amount seal-swelling agents, to help with leakage from radial seals (e.g., front crank seal). However the timing cover has no seal nor gasket. Once the anaerobic liquid sealant has failed, nothing will "fix" that (besides the aforementioned external Band-Aid). Pulling the timing cover is nightmare fuel, and there's usually no need to ever remove this, which is why the external RTV is a convenient way to eliminate that particular leak if present.
0- 05 sewing machine oil gives superior performance....lol ....I drive the E500 2000 miles or so a year. C36 i drive about 6000+ miles a year.
I use either pennzoil ultra platinum or Shell Ultra 0w40 or 5w40. Both rated excellent oils.
I'd apply the external RTV bead to stop the timing cover leak and then use whatever oil floats your boat. Yeah it will take a few hours of work but the cost is under ten bucks (plus degreaser & paper towels to clean everything).Which oil do you recomend for a time cover seal leaker should I go back to 20 50 High miles?
The 5-40 prob flows well but the 0-40 may be a little thin...0- 05 sewing machine oil gives superior performance....lol ....
Sewing machine oil was a bad joke please dont use it......I drive the E500 2000 miles or so a year. C36 i drive about 6000+ miles a year.
Nope, never seen new motor oil with a reddish tint. HOWEVER, each brand/type has their own unique color, so it could be normal for whatever the current M-1 15W-50 is.Has anyone experienced new oil changing color in the jug? I just opened a jug of 15W50 M1 and it looked much darker than it should. Almost red..
Yea change very year at lesstRemeber,,shelf life is 5 years. Its not like the oil goes definitive bad...but the additive packages wears down ,making the oil not up to the task it was designed for.
For cars driven regularly that get at least a few thousand miles per year, yep... doesn't hurt.Yea change very year at lesst
The additive package does deterioate over time.Especially the anti foaming additives.For cars driven regularly that get at least a few thousand miles per year, yep... doesn't hurt.
However, scroll back to this post. Engine oil doesn't "go bad" sitting around for a reasonable number of years, but yes, don't use decades-old oil in any engine you care about.
1000% this, I see best before dates on stuff that is ridiculous and completely unnecessary.While I think we all want to do what's best for our cars, we also must recognize that "pull dates" or "best before" dates whether on oil, tires or a can of tuna are always good for business...
I remember many years ago when internet forums were in their infancy, a guy posted that he put cooking oil in his engine because he was on a budget and it was so much cheaper…Old oil in an engine is better than no oil…![]()
Well....yes....that is a factor for sure.While I think we all want to do what's best for our cars, we also must recognize that "pull dates" or "best before" dates whether on oil, tires or a can of tuna are always good for business...
On alot of stuff it often is indeed completely unnecessary... But Best Before is nothing other than what lays in the wording...BEST before...and it often rings true . When it comes to the additives in the oil..they do loose their capabillities over time. So it is not just some " sales trick argument".1000% this, I see best before dates on stuff that is ridiculous and completely unnecessary.
How much is oil analysis neber did one?For cars driven regularly that get at least a few thousand miles per year, yep... doesn't hurt.
Prices vary widely. Blackstone is popular for various reasons but they aren't cheap. $40 for analysis without TBN, $50 with TBN, and that includes free shipping to mail the sample in. Blackstone does provide a personalised report written by a human, which is nice. And they provide a comparison to similar engines/vehicles, another nicety.How much is oil analysis neber did one?
Does the information tell you about the condition of your engine or just the oil and how do you use it?Prices vary widely. Blackstone is popular for various reasons but they aren't cheap. $40 for analysis without TBN, $50 with TBN, and that includes free shipping to mail the sample in. Blackstone does provide a personalised report written by a human, which is nice. And they provide a comparison to similar engines/vehicles, another nicety.
Lowest cost option that I know of, which I recent switched to after the Accutrack program ended, is the WIX analysis. Cost is about $20 or so (depending where you buy the kit), plus $5-$7 postage to mail the sample to the lab. Currently $20 at Amazon (link). This report is data only with generic comments, you need to understand what you are looking at. Look at the sample reports posted in reviews at Amazon to see what it looks like. This includes TBN, which is nice (TBN tells you roughly how much life is left in the oil, i.e. did you change it too early or too late).
More details here.
Look at the sample reports. It tells you the amount of wear metals in the oil, which gives you an idea of engine condition. And, it tells you the amount of additives in the oil as well. TBN, as mentioned previously, tells you how much life is left in the oil before it "needs changed".Does the information tell you about the condition of your engine or just the oil and how do you use it?
