This is a follow-up of a thread in the W126 section we hijacked. Basically its about getting rid of the mechanical fan clutch and replace it with an electrical fan setup.
All infos, Ideas and whatever are welcome here.
So far, Jelmer and me would like to be the first 2 guys that do such a conversion.
We want to use the Flex-A-Lite 410 twin-fan assembly with a variable speed-control that adjusts the fans operating speed between 60 and 100%. Also it let the fan(s) run approx. 30seconds after the engines stopped.
The Problem is, that its probably a few inches to wide and we would need a pretty good sealing at the integrated fan shrouds edges, as the air always will to use the shortest/easiest way.
I also thought about maybe getting a single-fan setup that will fit the E500Es radiator. Flex-A-Lite offers some of them with CFM Rating starting at 3000CFM. They are also cheaper than the twin flat 2500CFM Puller we actually wanted to use. However they have the downside that they are not working with variable speed control and only would function in the "On/Off" way.
I also thought about getting a hayden speed control instead. They are 50% of the Flex-A-Lite Price and can, if i got it right, also have 2 speed-settings.
Problem is i dont know if Flex-A-Lites single fan setups will work with 2 speed settings (I guess not).
