...and I run Type F or B&M trick shift synthetic in most everything I have...Pushing 10 years now in my white 91 SEC.
I'm a Big fan of the added Grab afforded by each.
jono
Please read the attached PDF.
Commercial TO-4 fluid gives the "grab" of Type F, and has all the special additives for drivetrain longevity. SWEPCO 714 20wt is the "hot ticket" for Porsche 928 automatic tranny's, because it is a TO-4 fluid, and the 928 automatic is 90+% our 036 tranny.
Since 2002, I've been alternating between SWEPCO and Petro-Canada (great exchange rate) TO-4 fluid, and have good success and longevity.
neil
http://www.500eboard.com/forums/attachment.php?attachmentid=28985&d=1398703571
Excerpt:
Transmission fluids for passenger cars may be divided into two groups: those that
contain friction modifiers, and those that do not. Friction modifiers are special additives
that make the fluid more “slippery” under certain operating conditions. Until the
mid-1970’s, Ford produced transmissions with relatively small frictional surfaces. The
bands and clutches had to be applied quickly with high pressure to prevent overheating
and wear caused by excessive slippage. This required a non-friction-modified fluid with
a higher static coefficient of friction than dynamic coefficient of friction.
Requirements of Commercial Transmission Fluids
The fluid requirements for automatic and semi-automatic transmissions used in larger
commercial vehicles are defined by manufacturers such as Allison (Type C-4) and
Caterpillar (TO-2, TO-4). The frictional requirements for Type C-4 and TO-2 fluids are
very broad. Both specifications can be met with friction-modified passenger car ATFs
and tractor hydraulic fluids, or with non-friction-modified heavy-duty engine oils and
Caterpillar TO-4 fluids. On the other hand, the newer Caterpillar TO-4 specification calls
for a fluid with substantially different frictional characteristics (more like a Type F fluid),
improved wear protection, and enhanced seal and friction material compatibility. The
demanding Caterpillar TO-4 specification defines a fluid that is essentially a unique,
specialty lubricant.
Powershift transmissions used in off-highway construction equipment have different fluid
requirements than passenger car automatic transmissions because of higher load factors
and the use of a wider variety of clutch materials. Current passenger car ATFs are
friction-modified for smooth shifting, whereas commercial powershift fluids are not
friction-modified in order to obtain the highest clutch and braking capacity. Powershift
transmissions require more active antiwear and EP protection than passenger car
transmissions because gears and bearings are much more heavily loaded. Passenger car
ATFs use a viscosity modifier to give good low temperature performance, whereas OEMs
such as Caterpillar and Komatsu prefer monograde oils (i.e., no viscosity modifier) that
are not susceptible to shear so that the gears obtain maximum oil film thickness.
European OEMs such as Voith and ZF also have a high shear stability requirement for
transmission fluids used in their commercial transmissions to assure adequate film
thickness. Powershift transmissions use a wide variety of clutch materials, such as paper,
elastomeric, bronze, and graphite, whereas passenger car transmissions use mostly paper
friction materials.
In 1991, Caterpillar issued a new specification, TO-4, with significantly enhanced
performance requirements for their newer equipment designs using new and diverse
friction materials. This specification replaced the older CD/TO-2 specification. The
differences between CD/TO-2 fluids and TO-4 fluids were highlighted in Team News 4.5.
Suffice it to say that the differences in viscometrics (shear stability), additive chemistry,
and frictional performance are substantial. Whereas a wide variety of oils met TO-2
requirements, only specialized lubricants meet TO-4 requirements. TO-4 fluids are
formulated to eliminate transmission slippage experienced with many CD/TO-2 engine
oils and to provide significantly improved friction and antiwear performance, resulting in
longer equipment life and reduced risk of field failure.
