It never dawned on me until I did some work on my E320 and had to remove a cover by the firewall. I do not have a cover in the same area on my 500E. Am I missing a cover that is on the passenger side of the firewall?
Most all 034/036 have no plastic cover/shield in this location.
However, super-early build (like, up to mid-1991) did have a cover here, which was slightly different than the 6-cyl item. It's been NLA for many years and, IIRC, may not even show up in the EPC or other MB systems. I believe MB deemed it unnecessary since all the modules were neatly tucked inside an air-cooled, waterproof aluminium container.
I have seen the cover on a few super early import US cars, built in late 1991 for the 1992 model year. I don't know if the cover was used much after the end of calendar 1991, but those would have been early 1992 model cars.
I don't think that one is original. Interestingly, the EPC doesn't show A1246261630 for USA/Japan-spec 036. If most 036's in Europe don't have this cover, it's likely an EPC error.
Also, although the EPC shows A1246261630 for USA-spec 034, I don't think I've ever seen a single 034 with this item. I strongly suspect an EPC error.
The early, 036-specific cover I've seen has metal clips riveted to the top.
The build date of my car is Apr/92 which would make it the latter part of the 92 production. The cover does finish it off nicely in my opinion. @Rouven036 does your cover have a part number stamped on it?
I can't verify if my cover is the number ending with 1630 since I don't have access to the car currently. it was there from the beginning when I bought the car back in early 2000. Also I "assume" the first owner hasn't had it retrofitted.
