Bissell 3624 Spot Clean Professional Carpet Cleaner
RicardoD
Every time I clean my car's interior I have longed for a fancy carpet extractor to clean my interior carpets. The one's that heat up the water, and have tremendous suction power. Since I don't have a full time detailing business I could never justify the expense of this fancy equipment. I started watching detailing videos on YouTube, in particular this DetailGroove YouTuber and really appreciate this guy's approach to things. I realized with some simple tools and the $160 Bissel carpet extractor I could get the results I wanted. I am super happy with this purchase and process and will be doing all my cars interiors this way. I started with my E500.
1)use your favorite carpet cleaner in a spray bottle
- I used Resolve as I always had good luck with that in my home carpets
- I purchased a small hand pump garden sprayer for $16 and a concentrated bottle of resolve that should last forever
2)Get a Drill Brush cleaning tool for carpets (the white one), three brushes in there for $10
- must have accessory
3)Bissel 3624 spot cleaner carpet extractor
- has a smaller brush head that will spray water and clear nozzle so you can see the water you suck out
- I just used hot tap water in the clean water tank with no cleaner it in
Procedure:
- vacuum loose dirt out of interior carpets first
- Just spray your carpet cleaner in the area you want to clean
- follow up with the drill brushes which is where the magic happens to agitate and clean all the fibers, break loose dirt
- then use the Bissell spot cleaner to spray the hot water and then vacuum extract it in one step
- follow up with just vacuum with the Bissell (don't trigger the water)
BEFORE:
AFTER:
DIRTY WATER in dirty water tank
Nice job!
Yes I too enjoy detailing channels and a couple years back bought a Bissell smaller spot cleaner. It was / is a great machine but the Bissell detergent for it was quite expensive and small bottles I had to order on amazon here in Ireland. (Regular shampoos foamed up in the particular unit I had)
So I bought a gallon of automotive carpet shampoo concentrate and a Henry brand carpet extractor. Once you clean a carpet with an extractor you won't go back! I did however quickly become obsessed with creating stripes with it
The quality wool carpets in our MBs of this era come up like new
I couldn't get the stripes with the Bissel, maybe I didn't use the right technique. I love the stripes however. When I get to my 911 with the tan interior I will see what I can do.
Great Tip! And filling up the dirty water tank with dirty water is just so cathartic!!!
Just FYI ---- Try to relieve the stress/bend on the hose end where it connects with the brush-wand. The design of the Bissell is such that it forces the hose end UP. My last Bissell lasted about 10 years until that unnatural hose-bend made the hose break at the connection to the brush-wand, and, of course, that part is not replaceable.
For my current Bissell, I store the brush-wand like this to relieve the stress.
Also the ZEP brand of shampoo that you can find at Home Depot is cheap and plentiful:
To each his own but no stripes! So unnatural. Our cars never came that way. I find the stripes and patterns really detract from an otherwise classy interior.
I used the bohemian method on the SEC. When I dynomatted the floor, I removed the seats, the foot carpets and the molded carpeting and used the pressure washer with some zep. But the front foot mats just un-button and lift out, making it much easier to clean outside the cockpit.
