Re: |Wiring Harness
Here are a few other photos of my own harness from some years back. There was nothing wrong with the harness, but I decided to replace it (proactively). After removing it, I split open the outer sheath and the attached photos show the results. The car had about 80,000 miles on it at the time.
Well, today I installed a brand new replacement upper engine wiring harness on my '93 500E - proactively, because I felt that it was just time to do it.
A few details while they're fresh in my mind:
- Upon removal and inspection, the wiring harness on my car was the factory-original one with an 11 Mar 92 date of manufacture.
- Even though my 500E has relatively low miles (63k + change), the harness looked identical to the photos that Gerry posted of his harness - many many cracks in each and every wire's insulation, brittle plastic clips, etc. It's amazing that these cars even start and run with this kind of degradation. The moral here is: mileage means nothing. If it's the year 2011 or later and you have a 500E with the original harness, then it needs to be replaced immediately. My opinion is that damage can be done to various electrical components if you run a degraded wiring harness. To me, it's a critical component.
- My 500E runs noticeably better with the new harness - and strangely, even though I have been on the look-out for issues, I thought it ran fine on the old harness. But it's definitely more responsive with the new harness, and possibly is running a little cooler (always a good thing for our cars).
- My new "late" harness, the 124 440 20 06 part, was manufactured in Oct 10, and cost $540 + $32 freight from Parts.com --- I feel that I was over-charged for shipping, as the harness arrived in a -significantly- over-sized box, but that's a different story.....
- The removal of the old harness + installation of the new harness is a relatively simple job. Undo the battery. Unplug the various connectors, all easy to get to --- undo the various 5mm allen bolts holding the harness down, all easy to get to --- guide the harness out through the firewall --- install in reverse order. Hook the battery up again. It should be a 2-hour job, if you work efficiently and enjoy a beer or two along the way.
- The job will take much longer if you get the routing of the wiring confused or incorrect. I had the benefit of a knowledgeable owner of a pair of 500E's who was able to guide me through anything I was unsure of --- if you don't, then be sure to take a lot of photos before you remove the old harness.
- Pay particular attention to how the four looms are routed through the firewall (top-to-bottom:
upper wiring harness,
lower wiring harness, diagnostic plug loom, water hose), the routing of the upper harness underneath the passenger valve cover's breather hose, and the 180-degree bend that the upper wiring harness takes between the firewall and the top of the valve cover.
- There are a small handful of U-shaped wiring "holders" that guide parts of the harness and keep it snug against the engine --- these will break. You will need new ones, or zip ties. New factory Mercedes parts = the best, always.
- Keep a small container handy to put all of the bolts + brackets + washers that you remove in --- that way, if you think you're done with the installation of the new harness, but you have parts left in the container, then you know you missed something.....
- This can be a frustrating job. If it doesn't go 100% according to plan and starts to take a while, then your lower back will hurt a lot, your hands will hurt a lot, and you'll swear a lot (in German). Take a break every so often. I suggest you have a few pairs of rubber gloves handy. I went through 5 pairs.
- Have a shower, take your 500E for a blast down the nearest Interstate, and then drink at least six of your favourite beers after the job is done. You'll feel much better.
- In case you missed what I said above... take many many hi-res photos before you remove the old wiring harness. Very important.
Good luck!!
