HOW-TO: Replacing W124 Rear SLS (Self-Leveling Suspension) Spheres
Site Honcho
Starting around the May 2022 time frame (and possibly before), I noticed on several long-distance trips up to the NYC area, that the damping and bump-absorption capability of my E500's rear suspension was severely diminished. It was basically not absorbing bumps, and every time I would drive over a crack, frost heave or speed bump the rear suspension motions would be highly exaggerated and very rough -- almost teeth-rattlingly rough.
I had replaced my SLS hydro-legs (rear struts) some years ago when I lived in Texas, so I knew they were in fine condition. However, I had never in 19 years of ownership replaced the rear SLS spheres (accumulators) before. I had purchased a new set of Corteco (which is the MB OEM for these accumulators) perhaps 3-4 years ago, so I had a new set in my parts stock.
The functionality of the accumulators is well documented, so I will not go into the theory here. However, I will say that the rear suspension damping quality of the E500E (and 400E420 models so equipped) leave a LOT to be desired if the SLS accumulators are not functioning well. What happens is that the rubber diaphragm on the inside of the accumulator, which flexes in and out with the up and down motion of the rear suspension and softens/damps the bumps, leaks .... and allows the pressurized nitrogen behind the diaphragm to leak out. With no pressurized gas to help absorb motion, the softening ability of the suspension is diminished severely, and basically the accumulator fills up with SLS hydraulic fluid.
For this job, it's advisable for a first-timer to budget 1.5-2 hours for the job.
There are some references to this job in other threads, although not formal HOW-TO articles, at the links below:
Difficulty is about a 3 out of 10 -- quite easy even for a novice DIYer.
Part numbers:
  • Corteco 21353060 (two required) -- around $85 apiece at AutohausAZ.com
  • OR Mercedes-Benz 140 328 02 15 (two required) -- around $90-100 apiece at typical online MB parts dealers
Tools required:
  • Cardboard, moving blanket or other protection for the garage floor under the car to catch spraying hydraulic fluid
  • Floor jack and two jack-stands (or a hydraulic lift if you have access to one)
  • Wheel chocks (if using a floor jack and stands)
  • Brake cleaner spray
  • Small plastic dish for soaking parts
  • 3-4 shop rags or towels
  • 11mm flare nut (brake line) wrench (in a pinch, regular 11mm wrench will work)
  • 17mm flare nut (brake line) wrench (in a pinch, regular 17mm wrench will work)
  • Small flat-blade screwdriver
  • 10mm socket, extension and 1/4" or 3/8" ratchet
  • Drip or oil drain pan (to catch hydraulic fluid dripping from loosened lines)
The first step you need to do is to raise the car. If you don't have access to a lift, then you can do this using a floor jack and two jack stands.
First, place wheel chocks to block the front wheels of the car, to keep it from rolling forward when the rear-end is lifted. You can see this in the photo below. Best to chock BOTH front wheels, for safety purposes.
Next, taking your floor jack, carefully place it underneath the rear differential flat area (NOT under the cooling fins), and carefully lift the rear of the car from the center, lifting the rear wheels a few inches off the ground. This will give you plenty of room to get under the car. You can see this lifting process below.
Once the car is lifted to an appropriate height, place two jack-stands under the lifting pads on the sides of the car, roughly inboard of the rectangular covers ahead of the rear wheels. This will secure the car in place while you are working underneath it. Lastly, before starting work, be sure to place some cardboard, or a moving blanket, or some other kind of protection UNDER the rear of the car to catch any spraying and leaking hydraulic fluid, as this job can be quite messy.
Next, you need to locate your two SLS accumulators. They are located in the forward corners of the spare tire well in the trunk. Open the trunk and lift the mat and plastic spare tire compartment cover, and you will see the two black spheres in the corners, as shown belos.
For the next step, get under the car, and locate the two SLS sphere connections. You should see one large SLS line emerging downward from each accumulator, a smaller line going into the side of the accumulator's snout, and three nuts that hold the accumulator to the bottom of the car. Note that one of the accumulator large lines, on the passenger side, is also secured to the bottom of the car by a metal bracket that goes underneath one of the nuts that secure the accumulator to the car. You can see this bracket in the first photo below. The driver's side large hydraulic line doesn't have this type of bracket.
Passenger side SLS sphere, viewed from underneath car
Driver's side SLS sphere, viewed from underneath car
With your 17mm flare nut wrench (you have one of these, right?), begin to loosen the large line going into the bottom of the passenger-side accumulator. It should loosen fairly easily, and will immediately begin oozing fluid. The hydraulic fluid will likely be very foamy -- this is normal.
GSXR edit: Alternately, you can de-pressurize the system by connecting a hose to the bleeder screw on top of the SLS valve above the rear sway bar, and loosening the bleeder. This will allow the fluid to run through the hose into a catch bottle, and reduce the amount of fluid that escapes from the threaded fittings at the sphere. This is optional, not required.
Tighten it back up, get your drain pan underneath the connection, re-position yourself so that you don't get sprayed with pressurized hydraulic fluid, and re-loosen the connection with your wrench. You will see a large spray of fluid, and then numerous smaller sprays as the pressure escapes from the system. Allow the fluid to run down and drip into the pan below.
Continue loosening the connection until you can turn it with your fingers. It will continue leaking hydraulic fluid during this time, so let it continue to drip into your drain pan.
At this point, with the one connector almost removed, take your 11mm flare nut wrench, and loosen the 13mm nut for the connection going into the side of the accumulator shout, as shown in the photo below.
Continue to loosen that 11mm nut until you can pull it free from the accumulator. Also you can remove the larger connection from the bottom of the accumulator. Both of these hoses will continue to ooze and drip hydraulic fluid, so don't be alarmed that they continue to do this.
Next, with your 10mm socket on an extension, carefully loosen the three 10mm nuts that hold the accumulator to the bottom of the car. They may be crusted with dirt and debris from years of being under the car, so you may need brake cleaner or other cleaning fluid to clean the area to get a better bite on the nuts with your socket.
After removing the three 10mm nuts, soak them in a small container with brake fluid to clean the dirt and debris off of the nuts. This will make re-installation much easier. At the same time, open your trunk and lift the accumulator straight up and out of the trunk.
Here is a view of the removed accumulator.
Here is a view of the hydraulic oil continuing to drip into the drain pan below the car, during accumulator removal from the vehicle.
A view of the removed accumulator (left) next to the replacement (right)
After removing the accumulator from the car, take a rag soaked with brake cleaner, and thoroughly clean the area where the old accumulator was by wiping the area down. Then CAREFULLY install the new accumulator down into the cleaned hole. NOTE: take notice of the orientation of the side hole in the accumuator snout, so that it lines up with the 11mm hydraulic line connector underneath the car.
Here is what the re-installed new accumulator looks like from beneath the car.
This next step is crucial -- DO NOT re-attach the three 10mm nuts that hold the accumulator to the bottom of the car. First, you want to CAREFULLY (did I say CAREFULLY) thread the 11mm hydraulic line and then the 17mm hydraulic line into the fittings on the accumulator (remove the plastic caps that protect the openings from dirt, first!). It may take some wiggling to properly thread the 11mm line into the accumulator, as it is a parallel angle to the ground, and a bit awkward to do from underneath the car. DO NOT CROSS-THREAD THIS LINE -- take EXTRA care to ensure that it is properly threaded into the accumulator. NOT attaching the accumulator to the car gives you extra wiggle room to slightly adjust your angle to help get that 11mm line threaded into the accumulator.
After you have both lines well threaded into the accumulator, THEN use your 10mm socket to install and re-tighten the accumulator to the bottom of the car. THEN you can tighten the two hydraulic lines, using your flare nut wrenches. You do not need to reef on them - just get them hand-tight with a little extra push ... what many of us call "Gutentight". Don't forget to re-attach the metal bracket for the passenger-side large 17mm hydraulic line underneath the appropriate 10mm nut, as shown.
Repeat this process for the other side.
After this, check the hydraulic fluid level in the SLS tank underhood. Start the engine, and visually check the hydraulic line connections under the car to ensure they are tight and not leaking/oozing/spraying hydraulic fluid. If everything looks good, turn off the engine. Then, using brake cleaner on a rag, spray the areas under the car where the accumulators mount up, and clean up any hydraulic fluid runs and spray. Also be sure to clean the accumulators in the trunk spare tire well, of any stains or wetness from your gloved hands while installing them.
You will probably leak out about 1/2 to 1 liter of hydraulic fluid into your drain pan, as shown in the photo below.
After running the car, be sure to re-check the hydraulic fluid level at the SLS tank underhood. Note the proper level using the SLS dipstick, or as a general / rough visual indicator, the tank should be filled roughly up to the level of the spring that surrounds the outside of the tank to keep it in place.
With that, you are done. It is likely that the second accumulator replacement will go MUCH quicker than the first one. The biggest challenge with this job is to ensure that the 11mm hydraulic lines are properly threaded into the accumulators and are NOT cross-threaded.
And that's it !
Wow! I never knew the accumulators in the 500E were in the trunk area. That's nice. On almost every other model I've worked on that had SLS the accumulators were in the undercarriage near the top of the hydroleg, and exposed to all the road grime and crud you would expect to have there.
A couple of observations/comments:
1.) If you're anticipating this job, and you probably will be, go in and spritz the line fittings with Kroil or some other penetrating oil in advance. These fittings are relatively soft, much like brake lines, so it's easy to damage or round them off if they're corroded.
2.) I have heard on more than one occasion that some suppliers won't ship accumulators. Apparently, due to them being a pressurized vessel, they can be interpreted as hazardous materials. This seems to vary from one supplier to another, so you may not encounter this.
Dan
Thanks Gerry! Been meaning to do this on my car which still feels a little harsh. With this complete, how does the ride in your 124.036 compare to that of the SEC? I bought an 86 SEC in May and have been working through it. It's lowered but the ride is quite plush around town, though admittedly not as tied down as the 500E at speed. I'm going to refresh some other items on the SEC suspension (upper control arms, Hydroleg mounts/ball joints, front shocks with the stiffer Bilsteins) in hopes of closing the gap but I'd love to retain some of the SEC 'waft'. I'm also hoping to make my 500E a touch softer with sphere replacement.
GVZ When I did this job on the E500 I found that the first one installed just dandy after I secured the unit to the chassis. The opposite side meant that I did need to remove the installed nuts on the sphere to get the line installed properly. So the advise you give is spot on - do not torque the spheres (read do not install the nuts) until after the lines are secured to the unit.
Threading the 11mm SLS hydraulic line into the side of the accumulator on the PASSENGER side was the much more difficult one. I think I struggled with it for a good 15-20 minutes before I finally got it threaded. The Driver's side 11mm line I think I got the second try.
These HOW-TOs just keep getting better. I wasn't aware the SLS option was available for the 400E/E420.
Go MB.
I’m doing this now on my wagon with 293k. First was done at 118k with MB. Then again at 250k with Corteco. MB is same price as Corteco at ‘our’ preferred Rev Parts sources. What else do you need to know?
Note that the -10 fluid is superseded by the -09. Some suppliers list the -09 for the W124 convertible top ram. Same 343.0 spec fluid, though.
Robert, what was the failure mode on the Cortecos with only 43kmi on them?
:runexe:
Didn’t do a full FMEA but I recently did perform a proper flush to both my 124s. Fluid was dark but can’t see how that would be the root cause, but it is an interesting coincidence. My receipt shows 000-989-91-03-09 fluid sourced from MB and not Febi.
Drew, as you know, my wagon is a hauler *and* my DD. She's not a princess although when people take notice she can be a bit of a ham. I can think of 6 trips YTD (and likely more), both work and pleasure, that her cargo has been fairly maxed out. So we do tend to put globes through their paces over most.
I wouldn't be too concerned with the German Corteco's on a car that isn't repeatedly taking heavy loads. I was more impressed that these were made 5 months ago! (literally, at the time of the posting).
I was rudely reminded how difficult this job is on the estate versus the sedan (I can't imagine this is different between the pedestrian 124 versus the 036, *maybe* exhaust interference may differ).
On the passenger side, the axle and leveling valve and hard lines are directly in the way to access the 11mm compression nut. And given how careful one must be not to cross thread - it's no simple task. It's doable, but give yourself 30-60m just on this single task. I'm tempted to drill a 2" hole from the sheet metal above (not structural) to access this bolt the next time around. I'm hopeful the MB units will give me >100k miles so out of sight/mind for now.
The ride was noticeably more bouncy while on a road trip with decent weight in the rear. The simple bounce test of the rear, where the back gave me a couple more deflections before settling was the dead giveaway.
Just a quick note- you should be able to check for a failed diaphragm in the spheres with the help of a zip tie. If you have access to the main port on the bottom of the sphere you can insert a zip tie into the port and see how far ‘in’ the zip tie can go. You’ll see a significant difference between a good sphere and a failed one with the failed sphere allowing a lot more of the zip tie to be inserted into the sphere than a good sphere.
Hope that makes sense.
Reviving, the ones in the 036 have finally failed from the originals.
Ramps or jacks? My standard process with the wagon has been ramps but depressurizing the system at the valve before starting the spheres and preparing for the car to drop. My thought process is 2-fold. At full compression you are pushing as much fluid out of the rams, so somewhat of a bleed I guess. I also hate to put any extra pressure on the diff bushing if avoidable especially if they are original. Is there any concern about using ramps instead?
I don't see any issue with ramps (plus jack stands for safety), besides reduced space to work with the wheels mounted.
If you bleed pressure from the port on the valve, everything should work fine. Any extra fluid in the hydrolegs when at full extension, will stay in there when you disconnect the hose. So, I'm not sure if there's any benefit to removing the struts while compressed.
Bigger question is, did you have a set of new struts on the shelf?
:wormhole:
I guess I wasn't clear. I'm only doing the spheres.
What I meant is compressing the rams (ramp) would push fluid out versus dropping the wheels(jacks). Probably negligible amount but that's how my mind was processing it...
Edit: As a back story, I had already flushed the system last year and the fluid is still clear-ish so I don't see much need to cycle the SLS valve.
AH! Now I understand. :doof:
Yes, compressing the struts would push a bit more fluid out. You'll still need to follow the bleeding procedure in the FSM after sphere replacement.
:banana1:
That is 100000000% easier on the 036 than the 092.
1.5hrs end to end, including a drive around the block and tools cleaned and put back. I had a couple more bottles of fluid so reflushed and glad I did.
Thanks @gerryvz for the clean write up.
