126v8 said:Hi I read in an earlier post that speed-autoteile sells LSDs for 500s.I contacted them and they want a part number.Does anyone know the number?Thanks guys
That looks sweet! But ~$3500 USD is pretty steep for a clutch-type unit that will need periodic rebuilds, and also may interfere with ASR just like the factory clutch-type LSD. That's why the Quaife would be preferred if possible, beside the fact that it's less than half the cost of the TCD, it doesn't wear out and also shouldn't interfere with ASR function.diaconovic said:Check this link ,look like they have an application for the 500E .
http://www.brabus.co.jp/f_tuning/tcd.html
Hi Glen,Glen said:Dave,
How exactly does the clutch type LSD interfere with the ASR? What % lockup are you using? And why would a torsen diff not interfere with ASR?
Yup, sure do, a 2.65 LSD. It's working great... helped me earn my first track championship for the 2009 season.Glen said:Thanks. That makes sense. So, do you still have the LSD installed in your E500?
gerryvz said:As an FYI -- a bit unrelated but a fact -- the standard US-model 560SEC and 560SL (W126 and R107 chassis) cars with the 2.47 rear end did come with limited-slip. This was unusual as most Benz models did not come with this feature stock. Not that this helps us with our E500E cars.
Also, as FYI, all of these 126/107 560 cars had ABS. The 1991 model year 126 560SECs had ASR as a factory option -- the first appearance of ASR on any Benz model. This was only specified on a fraction of the SECs brought into the US and was only available that last model year of the C126. I believe it was also available for the W126 560SEL sedans, as well. ASR was never available on the R107 SL models, although as we know it was certainly available on the R129 SL models during their production from model year 1990 onward.
Hi.NIIBE said:I had used genuine LSD for my 500 E with 2.65 gear, Yet The feeling was so poor that I had to change OS LSD 1.5way. I believe that This one is the best LSD for 500E.
No chattering but 100% lock with traction.
No need to use ASR off switch, because the lock speed is faster than ASR would be off.
And I am trying to change final gear ratio to 3.69 for late 11 second at strip.
You would be found OS LSD at This SEMA SHOW and PRI SHOW.
NIIBE
E500 but too much to list...
Hi.whipplem104 said:...........For those of you running high hp I have been looking into the possibilities of putting in a larger differential and half shafts. It would not be cheap but it is doable.
gsxr said:Ideally, I'd want to reprogram the ASR system to always engage the "snow chain program" any time the vehicle speed is below 20mph, but that's way beyond my capability.
In theory, yes; however I'm not sure it's that easy. IIRC, the snow chain switch didn't operate with simple on/off contacts, it sends two different resistance signals to the ASR module to indicate on or off. It could probably still be done but it would be a bit more work. Also, due to the different speeds desired, you'd likely need a separate BW FGS module for this purposes (separate from the one for the tranny). I may investigate this further at some point, but for now I don't find the problem bad enough to spend a lot of time messing with. However I would be very curious to get another opinion when someone else finally put LSD in their 500, i.e. do they notice the problem at all, or does it drive them nuts?J-Sauce said:Theoretically, couldn't you use a Bergwerks FGS to accomplish this? Just tap into the wires from the "B Switch" activator, and run them to the snow chain switch. Forgive me if my understanding of how the Bergwerks kit works it way off.
I have the Quaife in my 1992 500E, you can see it in action by looking to the left of this post - check out the avatar. Ignore the Quaife catalog listing, the QDF5V was originally built for someone who wanted to use it in their 500SLC, but Quaife did not ever update their catalog to indicate what other models it will fit (nor do they appear interested in doing this).Cadence said:I want an LSD for my '94. Has anyone actually installed a Quaife into their E500E?
The Quaife only lists it for the 500 SLC, but maybe our cars use the same diff![]()
http://www.quaife.co.uk/shop/products/qdf5v
Dave,, what was the cost of the LSD from quaife
