M119 Brabus 6,3 liter engine. Did it really exist? Plus M119 Brabus 5,0 liter AB 8 - 32 V stage.
Dave:
The initial order of the steel billet cranks was 12, originally I was also told that they were sourced from Mahle Germany, but later told they were sourced from the UK, probably Cosworth. This is hearsay so the actual numbers could be higher, but since the W210 with the 6.4L M119 failed to hit 200+MPH I was told that this led to the M120 EV12 versions which met their goal of a 4 door capable of 200+ MPH
From those 12 crankshafts, (9) 6.4 engines were initially assembled. I believe you are correct that Talbir purchased one of the remaining three for his 6.4 M119 build, Brabus probably used one on the more recent W124 E65 build, and one is supposed to be on display somewhere. My records show the following for the engines:
1. 1997 W210 Black, my car
2. Silver SLK, Bill Gates car that went back to europe after being in the USA for a few years
3. Black SLK, Tom Cruise
4. Vmax W124 Silver
5. Russia W124 silver/red interior
6. Russia W124 silver/black interior
7. Dubai, Red baron E500 with the 6.4
8. W210 estate, green in Germany
9. Talbir, car unknown
10. Brabus E65, Brabus Classic Collection
11. Crank on display?
12. Unknown
If the above information is incorrect please advise and/or correct. This information is what I have gathered over the years.
Jeff
What about this one Jeff https://www.500eboard.co/forums/index.php?threads/brabus-w210-6-5.11957/
"It was my understanding that only 13 of the special 100mm crankshafts were produced by Brabus and only 12 of those were used in engines; the 13th was sold separately and purchased by Talbir about 10 years ago, IIRC? Not sure if those numbers are accurate, or urban legend..."
When i was there last month, they told me they still had 1 crank left to build a 6.5 engine.
There's gotta be a custom crankshaft mfr that could replicate a 500E crank in 100mm stroke for far less than Brabus would want for one. Of course building the rest of the engine would cost a small fortune.
I'm considering going this route at some point in the future if I can't source a 6.0 M119 when I'm ready to get silly. Bryant Racing notes Mercedes in their list of misc:
http://bryantracing.com/products/miscellaneous/
Hmmm, I wonder what MB crank Bryant has done in the past?
There's always the 6.0L AMG motor for sale on eBay currently!
:v8:
Really nice article, I was wondering why the Monoblock II does not have a manufacturer stamp like the other brabus wheels (which are mostly made by Ronal), it turns out that Brabus manufactured the wheels them selves !
But two years in development!
As for 5.6L, it must have been an entry option on the M119 KE cars.
the 560 crank is a drop in, so that's Handy...same everything.
How precise is this fitting a crankshaft? Example. The 92,4 mm stroke. I reckon, me being a non-technician, this comes with a very accurately custom made crankshaft.
But Lotec had a 92,2 mm stroke. MKB comes even closer with a 92,5 mm stroke. Did Lotec and MKB had to make a completely newly designed and manufactured crankshaft? Or was just a slight little adjustment enough to make the 92,4 mm crankshaft fit?
@weide1 I'm not sure I fully understand your question, but as far as altering the stroke of a crankshaft, within small margins the journals can be offset-ground which reduces the diameter of the journal and changes the centerline, effectively altering the stroke. The connecting rods would either need thicker bearings or to be completely different to compensate. If I'm not mistaken - and I really am not an expert on this topic - I think I've heard that that is exactly what AMG did with the 6.0 cranks (anyone feel free to correct me). I worked for a shop that had this being done on ALFA Busso V6 cranks in very custom race engines.
As for fitting a longer crank in the block itself, clearances to the block walls would always need to be checked and sometimes reliefs made in the block.
In this link Talbir writes about a RENNtech 6,3 M119 engine with 525 hp. Brabus w124 6.5
I remember talbir's M119 engine build very well. AFAIK, that motor never went on a dyno. The 525hp number was based on the amount of airflow the ported cylinder heads would support. All theory, never proven. The engine was built in SoCal and shipped to the UK, then Talbir went silent. I was really hoping it would make the claimed power, but he was reluctant to reveal any engine specs, and the little we did find out was not sounding realistic. This was documented on the old 500Ecstasy forum, IIRC... now DOA/MIA.
Picture attached of the 6.3 custom engine build.
These guys have big expertise! They made a flat-plane-crankshaft for an LS7:
I was solidly into the plan and getting quotes from my suppliers for making an NA M119 of Doom.
By the time I was done, looked at the cost and time involved...and then looked at what AMG did with the M156... I opted to buy a few engines instead!
Jono
One revelation this is. Meaning the Brabus 6.3 really exists.
Nice find! I wonder what the bore & stroke was. 100x100 would be 6,283cc and allow safe cylinder wall thickness.
The Brabus 6.4L (badged E65) was 101 bore x 100 stroke; which IMO was pushing the limits of bore size.
Need the reference please. This might be the pre-6.5 configuration or a kind of prototype setup.
This is all i have from the brochure. The second image is from the IAA 1991.
Were AMG M119 engines, KE and LH and maybe even ME, availible without catalysts as well? Since the following is what the current owner tells and shows me.
This car. 1994 Mercedes-Benz SL60 AMG I´ve first archived images of this car in 2013.
ME-based M119 engines would not have been available anywhere without catalysors.
Early LH, and KE-based M119 engines were available without catalytic converters. All E500Es (and I believe including W140s and R129s using LH and KE-based R129/M119s) imported into the US as US models, had catalytic converters by US law.
It's possible AMG built some without catalysts, but I'm guessing they would be even more rare than non-AMG's without catalysts.
As Gerry said, I'm not aware of any ME-injected engines (119.98x) without cats. Might exist, but I've never seen documentation on it.
What M119 engine is someone claiming spins over 7000rpm?
Some early 500E's were available without catalysts as well. Very rare though. The non-catalyst .960 was rated at 245kw/333ps/329hp SAE.
Where did you get this information? I assume it's a partial printscreen.
And i notice something else. On the third line i read NV.
Must be Niedrige Verdichtung. Lower compression ratio. Indeed i read 8.8.
And only a mere 5 kW less. This M104 has NV as well but 15 kW less than oridnary M104.941 C 36 AMG engines.
AMG 500 E 6.0 KE Jetronic !!
Reviving an ancient post - with some information, although it may be not new:
I found this test from a French magazine on FB - in the article it states 1M-Fr. (would have translated into €125k in money of the early 1990s!)
So this Brabus engine on the R129 has KE-V/5 Jetronic, no words are meant for cat/non-cat, but I assume it did have one for France those days.
Bore 100mm, stroke 94.9mm, 408PS/610Nm, 1,865kg, 2.65 rear diff (stock, thus 170mph/275kph obtained at rev limiter) kept for 'proper acceleration'.
Reworked intake and exhaust manifolds, polished ports, modified valve timing and tweaked ECU.
Alberto
In some sizes 'by Ronal' was present (like on this R15), in some sizes (9.5x18) usually not present.
Even with all his magic tricks, Bodo B. was never able to manufacture a single wheel himself — Brabus still had to outsource production to an actual wheel manufacturer.
