Hi
I recently bought a 500e travel computer without the wiring harness, all i have is the instrument cluster and control unit.
Does anybody out there has the wiring diagram?
any help is much appreciated
thank you
The diagram might be buried in the WIS somewhere, but if you're hoping to wire it up without the harness, good luck. I'd buy the harness either new, or find one used in Germany...
I got one out of a parted out 500e. Tried to put it all together but it just doesn't work for some reason. I too realise I'm gonna have a hard time with it, but will do my best )))
No luck so far. I took apart the dashboard and examined the trip computer part thoroughly visually and using a voltmeter/tester. What I found was a dosen places where the soldering on the PCB had micro cracks. They could be found mostly at the connector pins-to-PCB soldering. I got it all repaired but didn't have a chance to install and test it.
