The EPC has 3 listing for item# 303 - Transmission Overload Protector B1 - part# A 002 545 45 14.
The last one with the following footnote:
"Inapplicable to vehicles with catalyst"
Now my question is of course:
Does my car actually have this part installed? (Porche part actually).
Because, my car does have the SA Codes 620 and 823.. (the vehicle is equiped with catalyst technique).
The reason why I'm even bothering is because I found an "old paper" (see picture) about this switch, in the desperate need of figuring out why my engine is cutting at 4000 rpms - sometimes 4800 rpms and 5500 rpms - at WOT and mostly after the following scenario:
1. kickdown from 3 to 2
2. WOT at 4000 rpms (sometimes 4800 rpms)
3. Cuts/misses and is locked at 4000 rpms
4. Easying the pedal - flooring it again - makes it go higher on the rpms
Or,
2. Flooring and hitting 5500 rpms
3. Hesitates - Takes about 1- 1.5 seconds to shift - with a fe
..The old paper printout says that "In case of complaints of misfiring at high vehicle speed, the overload protection switch and its wiring must be checked."
My transmission:
-Overhauled in 2010
-March 2011 - found nowhere to connect vacuum line - either item# 920 or 935 - not sure (see picture) - for the electric change-over valve (don't know what that is..) - quick fix: closed the hose - vehicle became somewhat calmer
-Neutral Safety Switch - been thinking about replacing this for a while now - I have the ASR light constantly on - now to the point where I cannot reset it by turning over. I have had the engine start only 1 time without the ASR light coming on in the past 3 months. This one time, and also from earlier experience, my rpms are LOW - about 450-500 rpms. But then sometimes it may idle steadily at 650 rpms. I think this is a familiar problem that many others have experienced too - at least what I've read.
Other than that:
-new plugs
-wires ok
-coils, caps and rotors checked and cleaned
-new mass
-new O2 sensor
-new upper wiring harness
-overhauled in 2010
-new fuel pump relay - no difference
Or,
My transmission:
-Overhauled in 2010
Other than that:
-new plugs
-wires ok
-new mass
-new O2 sensor
-overhauled in 2010
