Removed the gas equipment control unit and left a hole. in my country, such an option without a vacuum regulator was not supplied ((
Please tell me the part number. Thanks.
A1246802165 gives out a part with a hole for a vacuum regulatorI think you are looking for A124 680 21 65. That's the one for electrically adjustable steering wheel. Unfortunately it is not available for about 3 years now, and I could not find a used one in good condition (actually it is unbelievably hard to find it in any condition). Instead you can look for A124 680 16 65 and cut in appropriate holes for cover (what I see has been done also in the current one). A124 680 16 65 seems to be not available at the dealer, but it's much easier to find used ones in good condition.
yes, that's him! Thank you. OrderedThe USA version is A1246802765 if that helps? Should have no hole for vacuum regulator, and is used *with* adjustable / telescopic steering column.
yes, there is some charm in zebrano)), thanksTo go with zebrano interior - beautiful!
You can buy OE refills for the OE blade.I'm tired of low-quality brushes from different manufacturers, frameless, hybrid. None of them clean the windshield properly.
Original Mercedes-Benz W124 wiper blade. Will take its place in the spring.
Thank youYou can buy OE refills for the OE blade.
P/N: 000-824-36-27-01
$8 MSRP in USA. Usually lasts a few years.
unfortunately it was rejected. out of stock neither in Russia nor in Europe. hope only for the help of American friendsThe USA version is A1246802765 if that helps? Should have no hole for vacuum regulator, and is used *with* adjustable / telescopic steering column.
Looks like a can of wormsBought a headlight cleaner kit.
Most likely I will install on a separate button.
after installation, only the wiper arms will be visibleLooks like a can of worms
I’m sure it will look much better after you install it![]()
My family and I constantly live in neighboring Moldova. everything is fine, thank you.My heartfelt condolences to your country during these very of challenging times. How are you and your family doing?
I don’t like silver at all, but it so happened that w124 of the American version in my country is the same silver. But I don't want to repaint it completely in a different color. and I don't want my car's silver color blending into the w124 silver mass in my area.744 Brilliant Silver is the same color worldwide. If you see anything different, it isn't factory. Do you have more details about what you are seeing that is different?
Of course you can repaint in any color you want, just depends if you are trying to keep the car original or not.
I want to paint the whole car. but here's a puzzle for me. paint code 744 is the same for American and European version cars. but the actual color in the American versions is different. what is the difference between them? I think it can be painted in 775? what do you suggest? Thank you
since the purchase, the color of the car has not changed, just different lighting and different cameras for shooting. Everything looks great from a distance, but upon closer inspection it is clear that the car was tinted in many places, and at different times, so the car has at least three different shades of silver and I don’t know which part still has its native color@Prometey Personally I think your car looks fantastic as it is. I compared the first pictures of your car with your latest YouTube video images and I think the improvement is.
In conjunction with replacing your original wretched wheels with these smart looking ones, I love the two-tone look of your car. In particular, the lower panels seem darker than before, which to my eye looks much better.
With the changed lighting, my personal taste would be to keep your car’s exterior as it is. It looks very handsome and it looks perfect - you are not trying to make your car something that it was not.
Celebrate the 80s design of your car in all of its proper context!
View attachment 146965 View attachment 146966 View attachment 146967
yes, there are other beautiful colors, but conceptually I don't want to paint in a different color.Paint the car Bornite. Its the best color for W124 in my opinion.
Promtrey- if someone has a photo of the intact part, you might think about looking at a 3d printed solution. I’ve seen guys go from photos to a fully realized CAD model and then 3D part, with what seems like a really good return on investment…Tailoring.
The last two days I have been working on a bread box and a curtain.
Armed with glue, brushes, solvent and scissors, I felt like a tailor.
Pasted over the bar of the electric shutter. And I decided to take the risk of replacing the lower part of the electric shutter with the gray material that remained after cutting.
I glued the vinyl on the bread box, glued the wood of the bread box curtains. But I haven’t figured out how to make the broken part of the guide bread box yet, maybe someone has an idea?)
have not looked yet))) bought a working oneNice work! I took the easy way out to refresh the fading color on mine using a dusting of fabric spray paint. Have you checked and lubricated all the mechanicals?
yes, I know that Magneti Marelli is the same Bosh, and even ordered a set of new ones, waited half a year, but now only the left one is supplied, and the right one is no longer available for order.If it is not urgent you may spend some time "hunting" for them. They sometime appear new in affordable price, often in Latvia, Lithuania or UK. I advise to buy new, because in used ones, over 25-years old plastic might easily crack. Try to look for Automotive Lightning (or Magneti Marelli). Automotive Lightning was formed from Bosch lightning division and Magneti Marelli, so AL have the original Bosch quality. They even have very similar yellow stickers on them, here is one of examples:
For Mercedes W124 Front Driver Left & Passenger Right Turn Signal Light Assembly | eBay
Here are the Bosch and Mercedes numbers, you may use both numbers to extend search results:
Right:
Bosch 1315106903 / A1248261243
Left:
Bosch 1315106902 / A1248261143
Interestingly enough, I just attempted to order a pair, and was told the drivers side US facelift marker was NLA.It appears both sides are still available from Mercedes. It may just be the aftermarket version that is NLA.
https://partssearch.mercedes-benz-classic.com/parts/A1248261143?tt=automatic, manual
https://partssearch.mercedes-benz-classic.com/parts/A1248261243?tt=automatic, manual
1992-1993 Mercedes-Benz Turn Signal Lamp 124-826-12-43 | MB of Covington
1992-1993 Mercedes-Benz Turn Signal Lamp 124-826-12-43parts.mbofcovington.com
yes, color 775 looks pretty modern on the car, i used Mipo paint.That is exactly how I cut the first of two. For the second one I became impatient and substituted a hot exacto knife for the drilling. Nice work. Are you happy with the paint? It looks good in the video.
