Dave, I think there were some fitment issues/gap of the center section...With stock fenders, why did the bumper need modifications?
...but the center went sharp and there was a very large gap between the hood grille. Yes, and the edges have become splayed. It was decided to cut in the center in order to relieve tension. ...
AMG kit making my friends from Ukraine.I was going to ask you, with all the aftermarket parts you offer, if you doing any body updates/upgrades to your W124! Always liked the look of the late AMG styled bumpers!
I made this bumper based on amg gen2, but with some modifications for fog lights from golf 3.What bumper is that? The design looks similar to AMG Gen 2, but the fog lights are different.
Smart choice, MK3 fogs are readily available, very similar look as MB, also projectors (or alternate variations if one chooses). and very very cost effective!I made this bumper based on amg gen2, but with some modifications for fog lights from golf 3.
HellaSmart choice, MK3 fogs are readily available, very similar look as MB, also projectors (or alternate variations if one chooses). and very very cost effective!
Perfect! Correct me if I'm wrong, but original gen2 AMG bumpers using W202 C36/R129 Sport package (facelift) fogs (and those are stupid expensive). Your MK3 projectors are great looking alternative!Hella
yes, amg fog light fit to w124, w202 and w140. price from 200$ and more.Perfect! Correct me if I'm wrong, but original gen2 AMG bumpers using W202 C36/R129 Sport package (facelift) fogs (and those are stupid expensive). Your MK3 projectors are great looking alternative!
Original Gen2 AMG bumpers use W140 AMG auxiliary high beam lamps (long range / pencil beam), designed for standard 124 lights, to provide 2 fogs and 4 high beams.Perfect! Correct me if I'm wrong, but original gen2 AMG bumpers using W202 C36/R129 Sport package (facelift) fogs (and those are stupid expensive).
I'm already a little tired))Looking good, progress and progress!
?I need the help of those who have an electric blind and a third stop installed. Please measure the location of the third-party signal stand on the electric blind cover. distance from the edge of the lining to the stand.
Not sure I understand the dimension you need, can you draw lines on a photo or something?I need the help of those who have an electric blind and a third stop installed. Please measure the location of the third-party signal stand on the electric blind cover. distance from the edge of the lining to the stand.
Thank youNot sure I understand the dimension you need, can you draw lines on a photo or something?
Does the third stop have to touch the rear window? or not required? Thank you.It's pretty close to centered but favors the forward portion. On my cars it's about 10-15mm at the front/roller blind side, 15-20mm at the rear/glass side. Difficult to measure! Only 2 screws were used on my car, not four.
the third stop was in my car without an electric blind. I bought a stand for the third stop of the version for the electric blind, installed the electric blind, there was no third stop on the bar, so there are no holes or marks for them.The lamp assembly will touch the rear window when slid into place, there is a soft gasket/seal around the edge that touches the glass.
You install the base first (2 screws), then slide the lamp assembly into place.
The precise distance for the base screwed to the roller blind is not critical, as the lamp slides in/out and is held in place by serrations on the black plastic tabs. The distance is limited by the wiring since the holes must align and allow the wire to pass through. If your roller blind is not brand new, there should be existing holes where the original screws attached. Just use the old screw holes and everything should line up correctly.
I'm not sure. I've never removed either the rear parcel shelf or the roller blind. I don't know where the wires are routed.Do I need to make a separate hole for the wire of the electric shutter?
Thank you. if the wires are not visible anywhere from the outside, then there is a hole inside)I'm not sure. I've never removed either the rear parcel shelf or the roller blind. I don't know where the wires are routed.
: падение:
reply to facebook)The lamp assembly will touch the rear window when slid into place, there is a soft gasket/seal around the edge that touches the glass.
You have a complete set without an electric shutter. what is most interesting in the rear shelf there are marks on the bottom to cut a hole for the electric blind and there are marks to cut out a place for the third stop. but there are no holes on the metal plate of the electric shutter. I read a lot of forums and watched the video, everyone put an eye on it). I want the distances to be as provided by the manufacturer. Thanks.Not sure if that will help but here is a horrible photo of the stop lamp in my car:
As @gsxr stated, the lamp sits up against the window, with the small rubber gasket pressing up against the glass. It also looks like the base is positioned so it sits against the kink in the deck forward of the rear edge.
Get some silicone spray with a straw and lube the side rollers within the mechanism. That should resolve any blind sticking issuesPlugged in an electric curtain. She stood with me for five years and still sticks a little when folded. With each lowering and raising, everything is easier and more evenly done. Didn't use headrest protection. Connected according to the standard factory scheme.
Ok, thank youGet some silicone spray with a straw and lube the side rollers within the mechanism. That should resolve any blind sticking issues
Post in thread 'Prometey (E320)'what is that 'gas can' switch to the right of the wiper switch?
It didn't translate well, but I think that's for an LPG conversion.what is that 'gas can' switch to the right of the wiper switch?
right, switches to two operating modes: gas [LPG/propane] or gasolineIt didn't translate well, but I think that's for an LPG conversion.
these are 8J 16" wide rims from E500. They are machined and varnished. This is how I restored Evo rims. But I will use these rims only in winter, so I don't want to spend money on such a restoration.I don't think there is a Mercedes color code for the silver paint used on wheels in the 80's and early 90's. (???) Search the forum, I think other people have mentioned that Würth has a paint which matches well?
1995 USA models all had the machined face with clearcoat, which would be nice to retain, but is difficult to refinish properly. I assume that's why you are painting instead.
If you are not too particular, you can use Astral Silver (MB OE color) to spray paint your wheels.these are 8J 16" wide rims from E500. They are machined and varnished. This is how I restored Evo rims. But I will use these rims only in winter, so I don't want to spend money on such a restoration.
Hello Guest !
We wanted to let you know about a new resource that is now available to all 500Eboard members. This is a comprehensive database of all US-market (and soon to include Canadian-market) 500E and E500 models delivered for the 1992 through 1994 model years.
Data for this resource has been compiled continuously since mid-2003, and much of this information is seeing the light of day for the very first time ever. This new resource will allow you to utilize 500Eboard research and resources to track specific cars, their sale history, documented modifications, and other information that has surfaced over the years.
We are also providing analytics about the cars' production. This means that if you are curious as to how many "Signal Red" cars were produced for the US market with a black interior, specifically in Model Year 1993, you can now easily find this information. You can also find aggregated information -- for example, how many "Black Pearl" cars were imported into the US over the three-year span.
You can always find and enjoy this resource by clicking here (bookmark the site for easy reference!), or by going to the “500Eboard Registry and VIN Database” sub-forum below. You can also find a VIN Database button at the top of your screen, for easy access.
We hope you enjoy this resource. A LOT of blood, sweat and tears over nearly 23 years have gone into its creation.
