Well, I now have an officially licensed car-driving-teenager in the family. When I was 16, I and all my friends rushed as fast as possible to get a driver's license. However, these days, I have realized that many teenagers have no interest whatsoever in driving --- and doubly so for teenagers that grow up in dense urban areas. I am fortunate that my teenager desires to drive (even though my kid is not a gearhead...)
Well, my kid's car went kaput a week or two ago. See the below video. Look at that water pump pulley wobble and listen to that clanking!!!!
@jhodg5ck advised me that "this is about the worst I have ever seen!!" .... and I don't think that was a compliment.
. Note that this water pump was original to my 2002 E320 with 63K miles on it. It sure seems like a short-lifespan for this thing!
Here is the play in the water pump bearing with the belt and pulley removed.
@LWB250 and
@gsxr advised to me to change it immediately.
I ordered a HEPU water pump, LITENS tensioner, INA idler pulley, WAHLER thermostat, and GATES serpentine belt from RM European. Much to my chagrin, after waiting all week for the my order to arrive from Pompano Beach, FL, to California, I received my order on Friday afternoon only to discover that the HEPU pump was broken.... no doubt due to poor packaging.
RM European Customer Service closes at 1pm Mountain Time on a Friday so .... my plans for replacing the water pump this weekend were dashed. My local independent to the rescue --- (Junipero Serra Porsche / MB) --- I bought a LASO water pump that they had on the shelf at 4PM on Friday afternoon -
I drained out 8.25 qts of coolant (service records show it was last replaced by the previous owner @ 52K miles in 2017). My 2021 pandemic purchases of Zerex G05 and power-ratchet (which I have never really used) came in handy here. The water pump has 18 bolts and the klunky but value-priced Ryobi power ratchet saved me a ton of time.
Note the play in the bearings / impeller shaft of the OE pump ---- it was TERRIBLE!!!
Having the WIS / EPC in a virtual machine ---- an esoteric tool that I would have never been able to obtain and learn to use had it not been for all the wonderful advice on this board ---- was invaluable in looking up bolt torque specifications.
I carefully put everything back together and tapped two holes on the new pump housing for a bracket. These water pumps come with two gaskets - a rubber seal and a flat metal gasket - you must use one or the other, depending on what came with your car. My car came with the flat metal gasket.
I only made one mistake which wasted an hour when I had to uninstall and re-install the new water pump:
Well, now I have a properly functioning water pump without any leaks and a new a smooth idler pulley and tensioner!!
