Hello.
I am rebuilding a m119.974 engine and don't know where a couple of brackets need to be placed. I bought the engine already striped and received a lot of pictures but can't see the place of some of the parts. Maybe someone will recognize a bracket.
OK Reading your middle row first going LEFT to RIGHT:
1: Haven’t seen that exact one before but I believe it
might go on the inlet manifold bolts and is to clip cables to – crank sensor and vacuum lines to transmission. (The intake bolts at the very rear of the engine) Will need to think about this one further
2: Don’t recognise this one
3: That 2 hole flat one goes on the A/C bracket. On the rear edge of the bracket there will be a m8 stud with nut. This has a plastic clip to hold the knock sensor cables.
(Positive this is correct)
4: I recognise this one just can't place where it goes but let me think about it.
5: The top bracket is a piece of the black plastic spark plug cable ducting. It will clip back on.
6: See post #17 below for location and photos (below FPR vacuum hose)
I have lots of photos on my phone so I will see if I can post some useful ones below. If you look carefully you will see these brackets.
As a footnote – the next M119 I restore I intend to photograph and document all of the original brackets and bolts in their locations. The bolt brands vary on the motor even though the bolts are the same sizes in some instances. (Yes I am anal retentive about such things. But these are the differences that make for an epic resto – knowing with 100% certainty that the original fasteners are exactly where they belong)
