I just purchased a 1995 S500 That Has The M119 engine.
I am here because of the extreme helpfulness I see in this Forum.
I purchased this S500 for a great price because The guy could not keep it running past about fifteen minutes.
It would then sputter and run rough then die. I purchased Knowing that I could fix it (I hoped)
Well I did
. It turned out it needed the whole gamut. Wires,Sparkplugs,Caps,rotors,Fuel filter,crank shaft position sensor and even the insulator bowls.
I made sure to that I used the correct Sparkplugs (this seemed to be an issue I see that people are always saying to make sure of)
It runs now except it has a slight miss all the time.Not bad but noticeable enough to bother me. I have checked for Vacuum leaks found two fixed them. I also checked fuel pressure fantastic.
By the way I noticed the miss it has before I did all of this to it.My question is could it be an timing issue??
Turns over strong no noise for the typical timing chain guide noise.It has a 133000 miles on it.
Its a clean car no rust.You can tell it was maintained even though there is no records to check with.
Also it has the new upper engine harness. No lights on the dash either. So my next plan is to take the valve covers off and check the timing.
Just wanted people thoughts before I went ahead with this next bigger step.
Well I did
