Recently completed an engine out repair and resealed the transmission per one of the how to threads which was very helpful. I elected to replace the reverse friction disks and reseal the pump with inner and outer lip seals as well as new torque converter seal, new paper pump cover gasket and large o’ring. The car shifts well and the reverse delay is much better. Unfortunately, I have a smelly leak of smoking transmission fluid on the exhaust crossover below the bell housing. It doesn’t seem to leak until the engine is running. I coated the seals and o’ring with fluid and torqued everything per the specifications. Cannot imagine what is leaking. Any ideas? I plan to try running a borescope into the bell housing to see. I need to be sure before pulling it out for another try. Thanks for any help. One possibility is I did not use a thread sealer on the pump cover bolts. Other than that I have no idea.
Is there any "documentation" you do not have in that "GSXR Encyclopedia"
