Uh-oh. I can't tell from the photos, but it's possible that the fan support (thingy the clutch bolts to) may be damaged. Not only is that part expensive, it's many hours labor to R&R. Hopefully the repairs will be covered by the shop.
could you be more specific....?....you don't mean the pulley do you ?
Maybe, maybe not. If the car is running over 100C on a mild day with the AC off, cruising on flat roads, something is probably not right. Hard to pin it on the clutch without additional diagnostics though. To fully test the clutch you really need a very warm (or hot!) day with the AC on.So if your water temp is running 10-20 degrees above "normal" (9 o'clock position), on the highway on a mild temperature day, then your fan clutch is probably toast...? Seems like my car runs a few degrees hotter than it should, even with fresh coolant etc.
This test is mostly inconclusive, but if it will spin easily by hand with the engine/clutch cold, that's not a good sign and likely indicates a dead clutch. However resistance to the push by hand does not automatically mean the clutch is ok. Testing (OE) fan clutches is a serious PITA, as you recently discovered!What about the "push the fan" test with a cold car? My clutch was busted, and if I gave it a push, it would make a revolution or so. The new one comes to a halt almost immediately.
Per MB spec for the E500E, the viscous fan clutch on the E500E begins to engage at ~82C, whereas with other models this temperate was ~96C.Brief procedure to test your fan clutch:
The mechanical fan clutch will be fully engaged with the engine temp at 90C, and probably will have engaged at a lower temp. If it's not engaged by 90C, it's defective. With the car in park and temp at 90C or higher, pop the hood, and rev the engine slowly. The fan should roar loudly up to ~3500rpm, you can hear it disengage by 4000rpm, then let the revs drop slowly and the fan should re-engage by ~3000rpm. If yours doesn't do this, either the clutch is bad, or there is a blockage directly ahead of the clutch as it needs hot air to trigger the bimetal strip.
I've seen those specs in the factory docs, but I believe this is incorrect... AFAICT, the Sachs clutch for M119.96x/97x engines all engage at the same temp. It's also unclear if those numbers are coolant temp or air temp at the clutch itself, but it seems most likely to be coolant temp. This also doesn't match my "real world" observations on several M119 cars, particularly the ambient air temp and whether or not the AC is operating also has a significant effect on triggering the fan clutch. I should note that my 90C claim is on a warm day (>80F) with the AC on. On a cool day with AC off the clutch may not engage until the engine temp is higher.Per MB spec for the E500E, the viscous fan clutch on the E500E begins to engage at ~82C, whereas with other models this temperate was ~96C.
I'm not even sure if that would explain it... I have found more than one significant discrepancy in factory documentation, and I believe it's just a plain ol' error... same as the error in the specs which show the M119 clutch disengagement RPM's (which I have previously documented in a different thread).I believe it may have been initially correct for early cars, but MB may have revised it for the mid to late 1992 and beyond models.
Pics of ACM clutch are here. There is no sticker designating the country of origin, but the bearing is clearly Chinese.
Nope. Only source I know of is to buy one new... something like $525 USD from parts.com, last I checked.GSXR, do you know where I can source a low mileage OE fan clutch for our cars?
Absolutely correct. You have an ACM, Vemo, or other aftermarket clutch (re-labeled as Febi). That is most definitely not OE/OEM which would be Sachs or Horton.Well, I guess they are either wrong or simply mis-informed.
I just bumped into this comment.The cold upshift delay is easy to eliminate... disconnect the appropriate vacuum hose leading to the Bowden cable, and plug both openings - that should fix it. Just make sure you plug the correct one, as Euro-spec cars will have two hoses & two solenoids going to the Bowden cable... one is for the E/S switch, the other is for the cold upshift delay.
Are you saying that the cold upshift delay hose should be plugged, but the E/S switch must not be plugged?Just make sure you plug the correct one
There are two vacuum hoses on the right (passenger) side of the transmission, which attach to the Bowden cable assembly. One is for the cold upshift delay, the other is for the E/S switch function. If both hoses are disconnected and plugged, that's fine, as long as the vacuum source has also been plugged so you don't get a vacuum leak when the E/S switch is in "E" mode and also when the engine is cold. The vacuum source is behind the brake booster area, there are several vac lines present, and one or two vacuum solenoids where those two tubes would normally have connected. Kinda depends if the mechanic plugged them at the transmission end, or the chassis end, hard to tell without photos. It's nearly impossible to attach the tubes to the Bowden cable with the transmission in the car.I just bumped into this comment. Are they the two (mine is Euro-spec) vacuum hoses sitting at the right upper side of the transmission? A year ago or so, my mechanic plugged two hoses that were just hanging from the side of the transmission. He couldn't find anywhere to connect them. Are you saying that the cold upshift delay hose should be plugged, but the E/S switch must not be plugged? And what does the E/S switch translate to?
I would not and cannot recommend Meyle as a quality parts provider, across the board. I have seen first-hand the quality of their rubber products and it leaves something to be desired, particularly in comparison to MB rubber. I'm talking motor mounts, suspension rubber kits, door/trunk rubber seals, and so forth. Based on this experience I would NOT trust the quality of their fan clutches. Recommend going with a more trusted aftermarket brand (Beru, Sachs, etc.) or sticking with factory."Meyle" usually produces very high quality parts for a reasonable price. I think next Summer i will give one of them a go.
Check out the diagram of the Beru clutch... it appears to be the type used on the 119.985 engine with the hex-nut attachment, NOT the type that will fit our 119.974 engines. Sorry. Photo below of what I think the Beru clutch will will like on the back side (119.985 Sachs clutch in photo).Update on the BERU unit. Overview: http://www.beru.com/products/fan-components
Order Number: 0 720 002 043
Got it together with alternatives: http://www.daparto.de/Teilenummernsuche/Teile/Beru/0720002043
