Dan, I believe the OEM Sachs/Horton is a better unit overall. The bearings seem to last almost forever and they rarely if ever leak fluid. There has been discussion in the past that even brand new ones from the dealer may not engage at the correct/desired temps; Klink mentioned having to go through a half-dozen new ones to get one that worked how they wanted (back when these cars were under warranty at the dealer, IIRC). The problem here is that testing a new clutch is not easy, you need a warm day and engine temps high enough to know the clutch should be engaged. If you don't have a reference point, it's hard to know if your new clutch is "good" or "bad" (more accurately, if it's engaging at the correct temp, or not). If the car is running under 100C and you can confirm the clutch is engaged at least some of the time, I'd leave it alone.Alright, I am ready to do my Viscous Clutch. I have read this whole thread, and I am more or less fine with buying the OEM one (even though it is more than 700 bucks!) if it is better or correct. I am also happy to run the ACM one. I see that some of those aren't as good now, etc etc.
What's the current belief? Is the OEM one better in some way? Or just a plain old waste of money?
Also, should I replace the fan blades as well? If so, what's the Part number there?
Or just reuse?
The Wiki should have more info, but for a quick check, run the AC on a warm day (90°F or higher, if possible) and get engine temps to at least 90°C (or higher). See if the fan roars as you slowly increase engine RPM (car parked, driver door open, or window down, so you can hear better). The roar stops when the clutch disengages. It is not a binary on/off thing; it can be partially engaged and decouple at (for example) 2000rpm. When fully engaged, it will decouple very obviously at 3500rpm, and not re-couple until revs drop significantly (i.e., down to 1000rpm or so). If you can confirm the clutch is engaged / coupled, definitely don't replace it.
My complaint with the ACM is that it engages at a LOWER temp than OE and runs almost all the time; and it doesn't decouple until 4500rpm. Neither issue the end of the world. You need a different/shorter bolt to install the ACM. One minor advantage to the ACM is that it's easier to R&R because it's so much thinner. If you don't have the special tools to remove the OE clutch, you will need to pull the radiator (not fun).
		 (From a private seller who had it spare / surplus)
