Hi,
Thought I'd share my experience with in-car entertainment on my 500e.
I wanted something that sounds good but looks as original / 90's as possible, and one that has Bluetooth audio and phone calls, and something that's fairly simple.
Ended up with
I also considered buying more high-end speakers separately but decided to start with Jehnert's as they seemed to know what they're doing fairly well. Staying with the current setup for now, tho as it's not bad.
Hope this will help someone looking at a fairly easy way to significantly improve the 500e ICE.
Ended up with
- Jehnert full system (4-way speakers and door panels)
 - Blaupunkt Bremen SQR DAB head unit
 - Audison Prima AP 4.9 bit amplifier (serving 2 just channels in bridged mode)
 - No changes on rear speaker setup, at least so far
- The setup looks original
- Quality of craftmanship is good
 - The setup fools anyone who doesn't exactly know how a W124 door should look like to believe it's 100% original
 - Nothing sticks out from dashboard as the mids and tweeters are hidden under original grilles (the tweeter install requires work to get fully under the grille tho)
 - Forgot to tell Jehnert to drop their logo from the grilles :-/
 - Audio quality is good, but serious EQ tuning is required as bass defaults to "way too little"
- The amp has essentially a limitless digital EQ and DSP. Tuning takes place via PC based software.
 - I'd love deeper bass still, but just can't afford to break the interior due to a subwoofer. Sub in a trunk isn't for my liking either, as the trunk seems well sound-insulated.
 - In comparison, say, a modern Porsche with factory Burmester setup does sound a bit better to me (deeper bass) but this one can be tuned to be close.
 - The Bremen headunit works, but BT connectivity reliability could be better: Does not always pair. Does not default the iPhone to take phone calls
- Need to upgrade FW in hopes to improve
