The two screws are almost certainly X6/1, appears to be all Gray/Blue wires there.
I think you're right Dave. Lower screw secures 2 ties of cables + a single cable. All blue grey. One ties of blue/grey cables goes towards switches above HVAC, the other tie of cables goes towards power window switches. One single blue/grey cable goes to, my understanding based on JLAA's pointers to audio fader switch
@kiev, good progress through process of elimination. Let's try to answer the question "Does the blue arrow point to X6/1"?
The answers to the following questions may help us nudge closer to the answer:
Can you trace the gray/blue wire from the gear selector light socket? As you can see in the diagram below highlighted in blue, the gear selector light socket should connect directly into X6/1, and the light socket is right there, so close to the presumed X6/1.
Interestingly (or not). While blue/grey cables from
power windows and
mirror switches AND
rear head restraint switch AND
rear dome light switch
all go to X6/1
gear selector light, on the other hand
does not. Its blue/grey cable quickly joins into a tie of cables that
looks factory that joins other ties of cables and disappears into the depth, where the arrow points...
Does the rear dome lamp switch work? As you can see the the diagram below highlighted in green, this is connected directly to X6/1 and your presumed-X6/1 you mentioned basically all reads 0.0 or 0.02 volts. Note that I think the switch works even while there is no key in the ignition ... I think.
Rear dome lamp switch works, as in turns the light on/off, but is NOT illuminating. Rear headrest lowering switch also works, but does not illuminate.
**I thought, at the beginning, that it must be switches themselves, but after your pointers/explanations, I can see how rear dome switch's illumination AND rear headrest lowering switch's illumination connect directly to X6/1.
Does the fader switch illunination work? As you can see the the diagram below highlighted in green, this is connected directly to X6/1 and your presumed-X6/1 you mentioned basically all reads 0.0 or 0.02 volts.
The fader works, but does NOT illuminate
- With the ignition switch in the on position, do all the X6/1 wires still meter out at 0.0 or 0.02 volts? Does the rear head restraint release switch illumination work? See diagram below highlighted in red..... this is connected directly to X6/1.
Switch itself works, but not its illumination
Here is the thing. My cheap Amazon voltmeter always reads zero in default state. There is no "no reading" state. I checked several times both of the screws on X6/1, with ignition on, and headlights on, and sometimes they read "0", sometimes "0.01". More often it'll read "0". Maybe I'm generating static electricity?
I think the issue is with X6/1 connection. The upper screw hold a tie of cables, which contain red/grey cable, which my understanding is the powering cable? this tie of cables joins other ties of cables, including a tie that contains gear selector illumination cable and disappears into the depth (see arrow in the 2nd photo)
@Jlaa, looking at schematic, where does X6/1 get its power from?
