Subframe Rear Bushings
Kit 124-350-04-41 used to have different bushings, but now has the same bushings as the 124-350-03-41 kit. The "correct" bushings with tall tabs (129-351-15-42) are NLA from MB, and have superceded to the short-tab bushings (129-351-19-42). So yes, there is a difference, but you cannot get the correct bushings from MB anymore. Photos are at this link.
202-350-34-08 is NLA, but may work. Can you post some detailed photos of this bushing kit, since you have one? The Sportline bushings are stiffer, so it's up to you if you want to install stock bushings or stiffer bushings.
As requested: pictures of the 202-350-34-08 kit that I have. PN on the bushings themselves is 202-351-08-42 (not easy to read on the photo's). Not sure wether I'll install these or go with the ones that the catalogue suggests. Personally I prefer a smooth ride over a stiff one :)
Those look just like the late-style Sportline bushings. The part number on the rubber is 1 digit off vs the R129 number, but I need to double-check on that... could be the MB EPC number is not the same as what's on the rubber itself. Thanks for the pics! Do you mind if I add them to my website?
You're welcome, it was the least I could do ;) Not at all, go right ahead.
These are the subframe bushings I used when I did the my rear subframe refresh. They are boxed by Febi but the bushings appeared to be made by Boje (They had Boje stamped on them or the Boje logo, can't remember which but I'm sure they where Boje).
IF Boje supplies Febi with bushings would it be worth buying These (129 351 15 42) to see if they are any good??
Edit. I'm starting to doubt my memory, I'll try and check tomorrow.
Sorry for any confusion I may have caused.
I can confirm that the bushings I installed (normal W124) have Boge stamped on them.
Thanks @gerryfor pointing out it isn't "Boje"
@lightdude95, are you able to tell if this AFT Rear-subframe-bushing was made by BOGE or Lemfoerder for MB?
For instance, for the FRONT Rear-subframe-bushing 129-351-15-42, it was manufactured by BOGE for MB.
I'll have to take a look at them, I'm out of the country for the moment for leisure and afterwards I'll be gone again for business. I'll let you know once I get a chance to look at them! :)
@gsxr, @lightdude95 ---
Being in search of AFT rear subframe bushings, I found a pair of Boge 202-350-34-08 advertised on ebay.
I paid $70 for the two plus tax plus shipping. What I received was not two kits with two pairs each (even though they *should* be a kit), but two bushings without any additional hardware - 201-351-28-42 (made by BOGE with the Mercedes star ground off). Hmmmmmmmm......
Upon closer research, I found that these 201-351-28-42 were specified for the 190Es including the 2.5 EVO, and PRECEEDED the 202-350-34-08 bushings (see EPC note below showing the supercession). Does anyone know if these work for the w124 500E? A part lookup in the EPC shows that 201-351-28-42 were originally for seemingly all w201s
IMG_4157.jpeg IMG_4158.jpeg IMG_4159.jpeg IMG_4160.jpeg IMG_4161.jpeg IMG_4162.jpeg IMG_4163.jpeg IMG_4164.jpeg
Note that I found these to be:
336g each
70mm tall
Outer diameter 81mm / 78mm
Inner diameter 33mm
IMG_4165.jpeg IMG_4166.jpeg IMG_4167.jpeg IMG_4169.jpeg IMG_4171.jpeg IMG_4172.jpeg
EDIT - I compared the 201-351-28-42 to the regular pedestrian w124 AFT rear subframe bushings and the dimensions are the same. The only difference is that it seems that the rubber/voids area looks sliiiiightly different (less rubber & more open area on the 201 part as you can see in the first picture below) and the 201-351-28-42 part is 10 grams lighter than the 124-351-02-42 part when the scale is tared at the same time. I'm not too encouraged by this, so I started the return process back to the seller on ebay.
Urgh, I am late to the party on this. Jlaa your parts diagram is what I was looking for. THANK YOU No way am I putting in new pedestrian regular rear subframe mounts on my car. I will stick with my 190k miles originals but I think I am being stupid. So now we just wait forever for the classic center to make a run of proper .036 rear subframe bushings? I should have hoarded these when I first bought my car but was clueless then.
@RicardoD, I just updated the diagram with new information about the forward bushings. Please take note!
Also I think using new AFT pedestrian bushings is just the way to go. Reading through all the bushing threads, its seem that it is the FORWARD bushings that takes all the abuse and the AFT ones are more or less ok?
BTW here is the updated diagram w/ part numbers. Tricky Tricky.
(yes the updated info is about the forward rear subframe bushings and this thread title is about the AFT rear subframe bushings) ..... Administrators @gsxr @Glen @gerryvz maybe it makes sense to update the thread title to include both forward and aft rear subframe bushings.
@RicardoD , inspect your rear/large bushings as shown in post #30 on the "HOW TO" thread (here). If they are partly collapsed, replacement would be optional but I think pedestrian bushings would still be a good idea. If fully collapsed, definitely replace them. If in the future you source the correct bushings, you can change them out later on, the rear R&R is not a bad job at all with the 9110 tool.
:5150:
I'm about to do rear subframe overhauling bushing replacement+axl links+paint the subframe, install Wavetrack etc.. I'm bit confused what are now the proper mounting parts for the front and rear bushings?
I ordered Febi/Bilstein 10155 bushings (Boge) for the front as @Jlaa and other recommended but I didn't get any bolts or washers/end stops.
Can I use following parts which Xentry provides? For the front bushing spacer/end stop A1293520146 which supersedes to A129352014664 and for the bolt N910106012020 supersedes to N914125012238?
For rear bushing should be used pedestrian bushing A1243510242 but how about the mounting kit? Is that kit A1243506708 still valid as mentioned earlier?
I'll try to avoid ordering front kit (A1243500441) from the dealer which is not proper anymore since I have the bushings..
Or can I use old bolts and end stops? Or do you recommend to replace bolts and end stops?
Then how about the diff mount? The complete kit (A1243509708) is not available anymore and only few parts are possible to buy separately. How have you done the diff mount replacement? :detective:
Thanks,
Joonas
Im about to do rear subframe overhauling bushing replacement+axl links+paint the subframe, install Wavetrack etc.. Im bit confused what are now the proper mounting parts for the front and rear bushings? I ordered Febi/Bilstein 10155 bushings (Boge) for the front as @Jlaa and other recommended but I didnt get any bolts or washers/end stops.
That is odd! Did the Febi kit you received have the correct tall-tab OEM Boge bushings?
The front bushing stop has rolled again, from A1293520146 to 171-352-00-46. The bolts should be 914125-012238 as you mentioned above. Make sure to have the stop/washer oriented correctly, don't install upside-down.
I'd consider using the reproduction late-Sportline bushings available in Europe vs pedestrian.
Pedestrian kit is A1243506708, but it may be cheaper to order the bolts (201-990-03-04-64) and stop plates (201-352-12-46) separately - check pricing first. In USA, it's cheaper to buy separately. Remember these parts won't work with the late Sportline bushing design.
Ill try to avoid ordering front kit (A1243500441) from the dealer which is not proper anymore since I have the bushings..
It depends on the condition of the old ones, but often the originals are pretty corroded. I'd order new ones.
The original kit is NLA for the front diff mount, but there are some 140 and/or 210 pieces that can be used in their place. Search the forum for details. The replacement parts aren't identical but are functionally equivalent. I think the top & bottom rubber bushings have to be ordered separately - researched this a few years ago and already forgot the details, ooops.
:oldster:
I believe so. It seems that MB PN's have been removed etc. Pics attached. Maybe I didn't find the correct kit, I just purchased bushings separately.
The front bushing stop has rolled again, from A1293520146 to 171-352-00-46. The bolts should be 914125-012238 as you mentioned above. Make sure to have the stop/washer oriented correctly, dont install upside-down.
Ok. Intresting. Where did you find this 171? Xentry doesn't provide any information regarding this? I do have online Xentry access.
Id consider using the reproduction late-Sportline bushings available in Europe vs pedestrian.
😮 Can you give some more info about those? Link/URL etc?
Pedestrian kit is A1243506708, but it may be cheaper to order the bolts (201-990-03-04-64) and stop plates (201-352-12-46) separately - check pricing first. In USA, its cheaper to buy separately. Remember these parts wont work with the late Sportline bushing design.
Ok, thx. What if I use those aftermarket sportline bushings for the rear, are there new mounting parts still available which can be used or just use old ones?
The original kit is NLA for the front diff mount, but there are some 140 and/or 210 pieces that can be used in their place. Search the forum for details. The replacement parts arent identical but are functionally equivalent. I think the top & bottom rubber bushings have to be ordered separately - researched this a few years ago and already forgot the details, ooops.
I found out this kit from eBay.de Achslagerung Differential vorne Mercedes R129 / W124 500E | eBay
Has anyone tried this kit or would it be better to go with Mercedes 140/210 stuff?
Id consider using the reproduction late-Sportline [REAR] bushings available in Europe vs pedestrian.
@jnes, @RicardoD and I recently installed these reproduction sportline bushing in his car. They seemed v high quality. Price was high - from Japan. The seller claims that these were sourced from Germany. ベンツ W124 修理 パーツ販売 輸入 販売
These may or may not be the same as the repros available from Europe that have been purchased by @dreaming.haze for a much cheaper price.
I believe so. It seems that MB PNs have been removed etc. Pics attached. Maybe I didnt find the correct kit, I just purchased bushings separately.
Ah, you bought the bushings separately... that is not a kit. The kit available in USA included 2 bushings, 2 bolts, and 2 stop plates. But the Febi stop plates are junk, and the newer kits have questionable bolt quality. Kit = Febi # 10154. Single bushing = Febi #10155.
Ok. Intresting. Where did you find this 171? Xentry doesnt provide any information regarding this? I do have online Xentry access.
EPC / Xentry Parts do not show all supercessions. Only the Mercedes inventory system will show this. If you order 129-352-01-46 you'll receive 171-352-00-46, at least in USA. Not sure about Europe. The two part numbers should be nearly identical though, either one is fine if it's OE/Genuine.
See Jlaa's post above - there's more info on the forum somewhere with additional details.
The late-style Sportline bushings require different hardware. These require stop plates (202-990-05-04) and bolts (202-352-00-46).
I think those *are* the 140/210 parts, bundled and sold as a replacement for the 034/036 kit. Kit part number 202-350-96-08 may be another alternative, it looks very similar to the 140/210 but possibly with different length bolts?
Okay, just got Carrus rear subframe bushings + diff carrier bushing. Pics attached. Bushing kit has also mounting parts included.
To my eye those seem good quality, can't see any diffrence to OE parts. (Haven't see the NOS original one)
I bet that those are better than what are currently installed in my car and they seem quite worn out.
@jnes how did your install go? I am getting everything together in the planning stage now to make sure that I have everything I need for this project, including all the tools, but would love some real world experience on how it went with the carus bushings.
@gsxr I have the forward bushings for the rear subframe (found here on the board) at 124-351-19-42, bolts at 914125-012238, but can’t find the correct plate number, I must have written it down incorrectly ( i have 171352004626). Is that the correct forward rear subframe bushing for v8 subframe? I picked up a set of reproduction sportline rear bushings but need to order the fronts and want to be sure!
If not correct, can you clarify? I’ve been through just about every thread on the board here, but there’s so many part numbers and I probably am getting a little confused here.
Started on the bushings. I was able to get a set of the carrus reproduction sport bushings from a member here, and boy are they a big difference. The old ones were definitely worn out and the new ones are stout.
OK guys it turns out I got my parts suppliers mixed up. I ordered from the MB parts center which is not the Mercedes-Benz Classix center. I reordered directly from the Mercedes-Benz Classix center and they did have the parts, they are coming out of Germany, but the bushing is still available.
Just got the forward sub frame bushings from Mercedes classic center, I included a copy of my invoice and part numbers just in case anybody else needs it. These parts were not in stock in the United States, and did have to be ordered from Germany, figure on a 2 to 3 week turnaround.
If I order the front bushings for the rear subframe as Quick4door did, mboemparts.com tells me the bushing is not right for my car ('95 E420). But the price is favorable.
If I order the kit, 124-350-0441, it's $71 per side. Quick4door's total was only $74 for both sides. What am I missing?
The kit 124-350-04-41 had shot up in price to stupid levels, about 10 years ago... like $180 MSRP, $150 discount. So it was much cheaper (like, half the cost) to buy the components separately instead. And for a short while, it was possible to buy the tall-tab bushings separately, until they too went NLA.
Today, if you buy the components separately, it is still cheaper - if you buy from a RevPart dealer. For example, from Naperville, it's ~$45 total to buy everything separately. Prices below are rounded:
124-351-19-42 = $11 x 2 = $22 total (short-tab bushings)
171-352-00-46 = $6 x 2 = $12 total (stop plate)
914125-012238 = $5 x 2 = $10 total (bolts)
The 124-350-04-41 kit from Naperville is currently $71 as mentioned above, link for reference:
BTW - has anyone purchased the Febi 124-350-04-41 kit recently, like in 2023, to check if they are still shipping OEM Boge tall-tabbers? Or have those been replaced with either non-OEM, or short-tabbers?
I ordered from the Mercedes Benz classics center, not a third party site. I ordered through a third party initially and was told the parts were NLA. I reordered from mbcc and had the parts on 3 weeks.
I just got back my subframe and suspension part from powder coating. I managed to install bushings quite easy with Miller tools. Especially fronts were really piece of cake. But rears made some headache. First the the "pusher plate" will contact the side of subframe and new paint will scratch away which was annoying. For perfect result you have to modify the pusher plate a bit, cut away/hone slightly one edge to clear perfectly. Also for some reason bushing twisted a little bit that you can see from above that it is not in line with the subframe. I think that it won't cause any problems but for me it looks annoying.
Any tips how I can turn it back to proper position? The small notch is in proper place but twist is visible
I already take it off and tried to install but it turn again when reinstalling. I used some soap to lubricate. I wonder that those Carrus bushings might not be so accurate what comes in dimensions but the overall quality seems ok to me.
Ps. I made new sticker to subframe just like it was from the factory :coolgleam:
It's been a year since this was last discussed. I was confused then, same now. I bought front bushings (124 351 19 42) and plates (129 352 01 46 64) back then. I have nothing for the rears.
Would someone advise if the front bushings and plates are the best available and provide numbers for the best available replacement for the rears, please? Yes, fronts are cracking, and rears have lost airgap and plates are bent.
Hi @sheward
  • For the forward rear-subframe bushings, you want 129-351-15-42. These have taller tabs than 129-351-19-42. The bummer is that 15-42 is NLA from Mercedes. However, sometimes (but not always) FEBI reboxes BOGE-origin 129-351-15-42s. You might win a gamble.
This is the FEBI box that I purchased that contained BOGE-origin 129-351-15-42s:
These were the BOGE-origin 15-42s inside the box:
For the plates for the forward rear-subframe bushings, I have been advised by @gsxr to use the MB plates that you purchased.
@sheward - The best AFT rear-subframe bushings now are Germany / Japan sourced reproductions. @dreaming.haze brought a bunch over to the States from CARUS-OLDTIMERPARTS (see screenshot) --- he might have some still. The below photo highlights the weight difference between the reproductions for the E500E and pedestrian bushings.
Thanks, Jlaa!
I've placed an order for the Febi's from FCP. I'll let folks know what shows up. Interestingly, FCP lists these as aft bushings. Incorrect. I'll let them know.
@dreaming.haze, if you are looking in, I'm interested. Will PM you.
I received my order with the sub frame bushings and received the ones we want. They came in a Febi Bilstein box that states made in Turkey. There are no manufacturing names on the actual bushings.
I mistakenly ordered two kits not aware that one kit contains two bushings, so I have one kit for sale at $80.00 + shipping, same as I paid. These kits have the smaller plates, and I don't know if the larger plates ( 129 352 01 46 64) are still available as I already had them Myself.
I also have a set of the bushings with the lower tabs (a kit with bolts and plates) for sale. $40.00 + shipping. These are MB products.
Just like my experience with the front LCAs, I find myself in the NLA parts swamp. I’m trying to get parts on hand for a rear suspension refresh, I’m planning wheel carrier links, control arm bushings, and subframe bushings. After reading this thread I took a chance and bought Febi 124 350 04 41 (Ebay) hoping to get Boge reboxed bushings. No luck, the bushings have no meaningful markings and the box says made in Germany but it also says assembled in Germany with parts from Turkey. Are these “assembled in Germany Turkish bushings” acceptable? The last post on this thread is more than a year ago, any current tips or recommendations would be appreciated. I did find the Carus reproduction bushings advertised on EBay, think they were mentioned in this thread. Anybody have recent experience with these? Thanks!
J.M., I would probably go ahead and gamble on using the Türkiye bushings, IF they are the "tall tab" style shown in Jlaa's photos above. It will be very hard to locate old Febi stock with the Boge bushings.
The alternative is OE Boge bushings with the short tab, but IMO the taller tab is more important to reduce subframe movement, than COO.
Where these a confirmed fit ? :)
Many years ago there was a Mercedes dealer supercession from the original part number to the 202- kit. The original Spotline bushings haven't been available in a couple decades or more. The new 202- bushings are far more robust.
