I thought it was a good time to update this thread. Work has been so busy and the Cayenne Turbo does a good job of being a DD I’ve not had time for the E500. - although my rear window has not worked since April, I have just about got the car into the garage to replace the window mechanism. all done now and replaced, greased up nicely, runs lovely. I was lucky to find an NLA part on eBay back in April.
At the same time, we did an inspection on the car. This recognised a few issues that need resolution:
Rear stabiliser link damaged
Rear axle lower bushes worn out
Front LCA bushes have some play (ball joint ok)
Steering idler arm bush has some play
Gearbox mount worn out
Transmission cooler rubber line leaking
Radiator leaking coolant from top hose
Tyres 2019
AC could do with a regas
Not bad since I did not really do any major work since 2020. That said, the mileage has not increased much as it’s a second car. The tyres do not exhibit much use and they are good for inspection for another year (my car is due renewal January 2024) I probably keep them for now.
I have been toying with selling the car recently. I can’t help but think the money could go into something I could use more regularly without worrying about something breaking or someone damaging the car….maybe a 997.2 or 991 Porsche would itch the scratch.
View attachment 177745View attachment 177746View attachment 177747View attachment 177748View attachment 177749View attachment 177750View attachment 177751View attachment 177752View attachment 177753View attachment 177754View attachment 177755
