HOW-TO: Replacing Neutral Safety Switch (NSS, S16/3)
Site Honcho
GSXR edit: The neutral safety switch (NSS) is also referred to as the starter lock-out/backup lamp switch, and is switch S16/3 in MB documentation.
(Note: S16/1 is the NSS used on other 124 chassis without LH-SFI, S16/1 does not have the additional 4 pins for gear position indicator function.)
All,
Today I had to replace the neutral safety switch (aka starter lockout switch) on my wife's 1995 E320 wagon, which uses the 722.3X transmission that is quite similar to that of our E500Es.
The symptoms for this were the inability of the car to start when the key was turned, although the following observations were made:
a) the key turned all the way to the right and would spring back to the running position, but nothing engaged mechanically
b) all dashboard lights were on and tested fine; the battery had full power; no CEL or other diagnostic lights stayed lit
c) the steering wheel lock was NOT engaged (this prevents the key from being turned all the way)
d) the shift lever did not want to shift out of park, even with the brake depressed
e) the lever could eventually be wrestled into R and then N, and the car would start in N as normal
f) the backup lights of the car lit up when the car was placed in R (engine not running)
g) the solenoid that released the gear lever could be heard to audibly "click" (this is normal) when the brake was depressed, but the lever would not move downward to R or N
Thus, I deduced that the neutral safety switch (NSS) was the culprit, primarily because the car would not start in the P (Park) position, and was exceedingly difficult to wrestle out of this position once it was placed in and the engine turned off.
There were a couple of other potential causes for this, which could be one of the two cables requiring adjustment that lead from either the ignition switch or the brake pedal to the shift lever (these are safety mechanisms that are found in all 1990 and later W124s, according to GXSR).
I wanted to get this condition fixed right away, so I called up my local dealer (Mercedes-Benz of Houston North) and inquired as to whether they had an appropriate NSS in stock. It turns out that they did, so I drove down there at the end of the day and purchased it. This unit, for the E500E, is part number 000-545-62-06. It is similar to the E320 unit below but not identical.
Replacing the unit required the use of a 10mm open-end wrench, a 1/4" ratchet and 10mm socket, and two large-sized flat-blade screwdrivers.
Procedure is as follows:
a) Put the car up on ramps or jack-stands. I prefer ramps myself as I believe they are sturdier than stands.
b) Make sure the car is in P (N is OK too, but P is preferred). Engage the rear emergency brake.
c) Get under the car and locate the NSS. It is on the left-side of the transmission, immediately above the transmission oilpan on the side of the transmission. You will see a large white ring surrounding an inch-plus diameter black plug.
d) Turn this white ring counter-clockwise with your finger to loosen it. This will allow the large black plug to be pulled/pried straight out and off of the NSS. Move this large black plug and wiring harness out of the way by bending it away and tucking it under a pipe, tube or other wire (make sure everything is cool, not hot).
e) Using the open-end wrench on the bolt-head, and the 10mm socket on the nut end, loosen and remove the nut/bolt holding the clamp onto the metal flange protruding from the NSS. This clamp looks like a miniature battery terminal clamp.
f) Insert the blade of one of the screwdrivers into the open space between the clamp halves, and prise them apart. This should move them enough that you can prise the entire clamp-head off of the metal flange with your other screwdriver. This can be done in two steps, or together depending on how dextrous you are and how much room you have to work in.
g) After prising the clamp off the metal flange, use your flashlight to inspect the rubber shift linkage bushing that is pressed into the linkage member just above the clamp. If it is bad, use your flat-blade screwdriver to remove the small metal clip and separate the piece of metal that the bushing is pressed into from the linkage itself. This is a separate operation to remove the bushing and press in a new one; I won't cover that here.
h) Use your 10mm socket and remove the 10mm bolts that hold the NSS to the transmission housing. One bolt is immediately to the right of the metal flange; the other is at the upper right (1 o'clock) position of the NSS, and is difficult to see except with a flashlight and looking directly up there to find it. You MUST remove the clamp/linkage from the metal flange BEFORE you remove this upper-right bolt.
i) Remove the NSS from the body of the transmission. It should slide out to the right (not much space, but it will slide out). Carefully note the position of the black arm with the pin in it on the left side of the surface of the NSS (it's to the left of the large plug with white retaining ring that you initially loosened.
j) Installation is the reverse of removal. The one key thing that you MUST do is to ensure that the black arm's little round pin is inserted into the hole in the clamp/linkage assembly when you re-attach it. Tighten the 10mm bolts hand-tight, but don't overdo it. Same for the 10mm clamp bolt. Make sure it's snug and give it an extra partial turn, but don't crank it down so that it cracks the NSS housing.
k) After re-assembling, get in the car and ensure that things shift smoothly and that the car starts in both P and N. If it does not, or the linkage feels a bit notchy, you will need to adjust the NSS a bit by loosening the 10mm bolts slightly and re-positioning it on the transmission housing. This is easy to do, but you have to dis- and then re-assemble everything to access that upper-right 10mm bolt. This adjustment is why the mounting holes on the NSS are slightly oval -- to allow for moderate adjustments if required.
Total time for this job is around 1 hour, as long as you have a lift or enough room to work under the car.
Hope this helps.
Note that the part number shown in the photos attached below is for the E320 W124, NOT the E500E.
Re: Neutral Safety Switch
Thanks for the write-up, Gerry. We haven't had this problem yet on our wagon...keeping fingers crossed! :-)
Been through this on both of our 104 powered 124's. There is a FEBI brand switch available for about $12--I don't recommend it. I've had two of these cheap switches fail within a few months of installation......no problem with the genuine MB part.
One note on the installation, the switch arm should be pinned to the switch body prior to install. Shifter should be in N (if memory serves me corretly, might want to check WIS) when tightening the two bolts that hold switch to tranny. After bolts tightened, remove pin. this ensures proper orientation of the bolt in the elongated hole.........
J. M. van Swaay
I just did mine yesterday - for the 4th time.. Anyway I think you left out a step that involves alignment. You need to put the car in N (during reassembly) and use an alignment pin/dowel (I used an allen wrench) and insert it into the hole in the pin you mention and the thru the hole you can see in the pic you posted of the NSS.
Why the 4th time you ask - oh make SURE you take out the alignment pin before you shift your trans or the pin will break off the cheap ebay NSS switch you just bought.
And oh yeah the 3rd time was just to prove you can not just clean up the old one.
The 1st and 2nd time - you don't want to know...
Yes, I'd heard of the alignment that is required. What I did was to CAREFULLY (as I could given the clearance) note the position of the switch, and also the moving arm with the pin that goes into the transmission linkage.
Upon reassembly, I tried to keep these measurements exact as I installed the switch. After I tightened everything up, it all seemed to be just fine and I went through the gears and a short test drive and all was well. Thus, I didn't have to hassle with the "alignment" step.
I had everything in "P" during the removal and assembly process and didn't have any issues.
I've heard horrible things about the aftermarket FEBI switches as well, so just decided to pay the $63 for the MB switch at the dealer (we get an awesome discount from them with our MBCA membership card; perhaps the ONLY compelling benefit I get from MBCA membership...the Portland dealer barely gave any discount on MB parts with MBCA membership; we get them wholesale from the Houston dealer with MBCA membership card). I can't complain about $63. Then again, I always try to go with factory parts (or known-good OEMs) whenever possible.
Neutral safety switch
Here is a view of the E500E neutral safety switch. This located on the side of the transmission. This switch controls the rear "back-up" lights.
These are known to go bad with age and use, etc.
It is part number 000-545-62-06, callout # 339 on the diagram below.
Re: Neutral safety switch
Gerry, is this also called the gear position switch or is that a different part?
Yes this is the gear position switch. The little arm that is pointing straight down on the right side of the switch in the photo, goes into the shift linkage arm and changes position depending which position the shifter is in.
thanks for the clarification Gerry, I diagnosed a faulty switch on a friends 500E. It was a B*tch to find as the car was not throwing codes but you can see an alteration in the idle when in P or D.
Re: HOW-TO: Replacing Neutral Safety Switch
I'm curious ... for anyone else who has had a bad Neutral Safety Switch on their 036: can you please post the symptoms that you experienced that led you to believe that the NSS was the cause?
1. Reverse lights would not activate upon shifting into reverse.
2. Limp Home Mode began occurring when manually downshifting & then stomping on the accelerator for assertive passing activity.
A new NSS resolved both issues.
3. Limp Home Mode began occurring intermittently, usually after a WOT blast.
4. Frequently got ASR code 30, EA code 2 or 6 (need to check my notes).
Interestingly, my wife's wagon had the same problem again - bad neutral safety switch - just shy of two years after the last episode. I actually printed out my instructions here from the last time I did the job and they worked just fine with no changes or clarifications. The job took about 1 hour, more or less taking my time. I checked the shift linkage bushings carefully and although they were discolored brown, they were still intact (not cracked) and fairly firm. So I decided not to bother changing them.
The symptoms this second time around with the neutral safety switch was mainly a "no-start" condition. I could hear clicking coming from the solenoid and this fooled me into thinking it was the starter. So I replaced the starter (which was original, 180K miles) and that didn't solve the problem. Further troubleshooting with the other electrical components in the system (ignition switch and the alarm relay behind the instrument cluster, both of which I had new spares on hand) indicated it was the neutral safety switch. I was able to "hot wire" the car with a direct lead from the battery to the starter lead, so this told me that the culprit problem was between the key and the firewall (where the hot wire location is). Troubleshooting is well documented at the PeachParts forum in case you have this problem.
In any case, the misbehaving NSS acted a bit different this time around. As I said I had a no-start condition but unlike the previous time, the car shifted into gears easily and with no resistance. However I could not start the car either in Park or Neutral. I just got a clicking sound underhood/at the solenoid when I turned the key. So the NSS was not passing the "start" signal from the key onto the Starter.
I took the opportunity having the car laid up for 10 days in the garage to clean up the belly pan and underside, and I found a couple of minor oil leaks that I'm going to have to take care of. Nothing serious, but I hate oil leaks.
In any case, since the E500E neutral safety switch is of nearly identical design as that of the E320, I hope this thread has relevance for someone if they have a problem with it. I learned a lot about diagnosing the various electrical components of the starting system. And changing the starter on an E320 is a fair bit easier than doing same job on a 500E. It's about an hour to come off the car, and about 30 minutes to install the new starter.
Gerry,
I had my wife hot-wiring the starter on the 300e after it's NSS failed the second time. Shop was quite impressed that she was willing to whip out a wire and place one end in the battery (+) and touch the other to the connector on the bulkhead. She's a sweetie and was willing to do it for a few days until we got a new switch.
My wife would only do that under the most dire of circumstances. It's a given tenet of our marriage that she will have a correctly operating car :) One benefit to owning other cars is that there is always a backup or two :) Now that the Houston summer heat is going away, it's a bit more comfortable for her to drive the 560SL. And heck.... just having turned 51K miles it's a nice car !
AS usual many thanx to Gerry for his wonderful write up ! My reverse lights stoped working and I had limp mode from time to time. So I decided to install new NSS.
The only think I would like to add to Gerry is that get those little bushing along with the NSS , cuz with 100K+ miles on a car most likely they going to be worn out.
My shifting was really loose and I heard metal clicking when going through gears so I found out that was the bushing.
So now I got back my reverse lights and my shifting is super tight, what I mean it goes accurately through gears like it is new.
I did not get any limp mode (ASR light) so I think this issued was fixed to by replacing NSS.
P.S. I took NSS out few times cuz the first time I did not get those little bushings. So any time I installed , it was perfect I did not need any adjsutment , cars start in N and P . So I do not think somebody might have an issue and need adjustment .
The day after I left for Europe, my wife called me there to tell me that her car was stranded in the local supermarket parking lot (a short 1/2 mile walk away from our house) and that it wouldn't start. I told her to walk home and come back in the evening when things were cooled down, and that I bet the car would start just fine. It did. She drove the car home that night and left it in the driveway, driving my 560SEL and 560SEC for the remainder of the time I was gone out of the country.
This past Monday July 1, I ordered a new neutral safety switch from parts.com (via Internet from Amsterdam), which was delivered to my house on Friday July 5, via FedEx. I think I paid $52 + shipping/handling for this switch.
Friday night I replaced the NSS in my wife's E320 wagon for the THIRD time since we have lived here in Texas. It was a 45-minute job under the car in the fading daylight.
My mechanic had confirmed to me some months ago that they have been seeing numerous early failures of these 722.3 neutral safety switches (factory MB parts).
I have a spare NSS for my E500 which I've never had to use, and will from now on keep a spare switch on hand for my E320 wagon as well, seeing as these are going out every 18-24 months.
Indeed it is a good idea to order up 8-10 of the shift linkage bushings (don't forget to order same amount of the metal clips too!!) particularly if you have more than one car that requires the bushings. Both of my wife's wagon's bushings were in decent condition -- I certainly checked both bushings while I was under the car. Now that I have the special bushing replacement pliers, doing them is a snap. I recently changed both bushings on a colleague's 1995 E320 sedan in about 15 minutes using the special magical "shift linkage bushing pliers". Highly recommended tool.....
The day after I left for Europe, my wife called me there to tell me that her car was stranded in the local supermarket parking lot and that it wouldn't start. I told her to walk home ...
Gee, it sounds like your wife's wagon is a real lemon, Gerry. You should sell it to me and buy her something more reliable, no?
:D :D
This unit, for the E500E, is part number 000 545 62 06. It is similar to the E320 unit below but not identical.
Can anyone tell the difference? between the 49 and the 62... I know the 49 is for 5 gearboxes, but I have seen places where they sell the 49 as a 500e fit.
I just did the 62 and all is well. Can't speak for the 49 never heard of that being done.
Chris
I am about to change the NSS on my 91 300SE, I was not able to start the car in park and only in Neutral for a few weeks, even though it seem to be back to normal as I am able to start in Park, however I am going to change the NSS, you mention about changing the Gear Shift Bushing, exactly how many do I need to change, from the youtube video posted by Ken at Mercedessource, he only discussed one bushing, but it seems you are recommending changing (bushings) meaning more than one, has anyone been able to change the bushing without that special tool that Ken sells. thanks
There are two bushings. Often only one is bad.
Yes you can replace the bushings with hand tools without requiring the special tool. It will just take 30-60 minutes to do it. It can be a frustrating job. Some people make a bushing press with a nut-bolt-washers but I used a screwdriver and pliers. I have a how to here on the site about how to do this job.
Terribly frustrating. So much so that I ended up just slicing the bushing at a bias and installing it in 2-seconds (after struggling for an hour). I positioned the cut at the 6 o'clock mark, straight down, since the shaft applies force laterally from that position and the bushing has been fine and still looks fine when I did my NSS a couple months ago and inspected it. Not at all recommended procedure but my patience got the best of me this time...and it still works fine with no play. I should mention that I also gate shift my car all.the.time.
Thanks very much Gerry and Kwontumspeed, this will be a challenge changing this part, I will probably just take it to the mechanic, but thanks for advise and recommendations
Hi Jerry
I just wanted to thank you for the very detailed explanation and procedure you did in post #1, I printed it out and will ise it as my installation guide
Thanks for the write up Gerry. Did this on my 034 today. I followed your description, but put in the adjustment from the FSM. I put it in neutral, a 3 mm allen key work perfect. Then I just tightened the two screws up, and continued per the write up. Took maybe an hour all in all.
Last time I pulled codes on my 92 500E using a Star C3 I got fault on this switch, S16/1. But there's nothing wrong with the car, it starts in P and N as it should and the back up light is workong. How can that be?
It is likely an intermittent fault. And, depending on the exact failure mode of the switch, the car can run & drive normally without any obvious side effects.
Remember the NSS has several functions, the starter lockout and reverse light are only two. It also sends a gear position signal to the engine computers (E-GAS module) and can trigger limp mode if that signal is inaccurate.
:cel:
Same here, but since it’s never been replaced on my car, and I’m chasing some gremlins I decided to replace it. The movement of the arm on the old NSS felt anything but good compared to the new one. Also there were water dropping from it, so I suspect it’s not waterproof any longer. That would explain the intermittent codes, even though it’s still working. I work with fire and water damaged machines and electricals, and I’m still amazed how much water most electrical things can endure and still work ok.
I think I’m gonna take it apart to see how it looks inside.
Did you have any typical NSS symptoms when replacing it lowman?
To be fair..i reaaally dont remember if i did have any particular problems related to the NSS.,.as this was in the early beginnings of the ownership of the car..and getting an overview of what was causing the SUPER intermittent / no start/Stalling issue i had.
But im preeeetty sure i had a direct "Fault"code on the NSS switch...But any direct symptoms...i dont think i had.Appart from the Crank only/no start/ Glitch issue
i will check my photo folder...to see if i have saved any faultcode printouts
Would a faulty NS switch cause sudden drops in power? My e500 will suddenly loose power for a fraction of a second then return to normal. It feels like a misfire but I’ve been told the engine is fine. Could it be the NS switch cutting the drive then returning it again? How could I test for a faulty switch?
no it shouldnt.But you never know.BUT...this does seem like the issue i had with my car.The "hickup" was actually a power distribution issue..to the ECU/LH unit.In the end the car would not start because of the lack of one of the power feeds from the BM module To the LH unit.There was a break in a Z point inside the inside wiring harness to the engine.Not the one on top of the engine..but the wiring harness going between the ecu"s..and fusebox.
I do have a video of this particular issue.
This would also lead to faultcodes in the ASR module and such.."No can signal from LH unit"..because of the lack of power to the LH...it would be dead for a second..hence not beeing "Awake"and giving Can signal to the ASR and stuff.
Run a short test with the HHT/DAS today and found a actual fault from the NSS. The only thing I noticed, or what I think i noticed, was that there was no shifting behavioral difference in E or S mode. No ASR light/limp home mode at all. Started always fine. Switch is 11-12 years old with +/- 3500km on it. Checked actual values of the gear selector lever and there it is always in -F- except in gear position 2 and sporadically 3. All other positions, P, R, N, D and sporadically 3 are not recognized. Moving/wiggling the lever a little bit up and down doesn't change anything so I think it's not an adjustment issue.
Ordered a new one. Currently about 150 euros.
A frequent failure item on ALL LH equipped MBs, NOT only those with ASR. The "Fs" showing up in certain lever positions or flashing on the actual value screen while driving is usually how they test out.
Here you can see the worn insides of the old switch on my car.
Corrosion,and worn contact points.
Of course, the area that usually causes the E-gas and cruise/idle control faults are the variable resistance contacts that are sampled by the feeler pad visible on your first picture. This is the part of the switch that communicates the actual lever position with EA and T-LLR control units.
The couple that I had cut apart had cracks in the little resistor board.
I also ordered a new NSS for my Nautical Blue back home as I was down shifting aggressively on highway to overtake and the ASR light and limp mode became present.
According to the symptoms it has to be the NSS from the tranny or the small Throttle Switch behind the gas pedal.
I will replace mine in September when I go home for vacation.
I replaced the Neutral Safety Switch on my E500 today. I’d had this factory spare part in my stash since 2004.
I had been having some issues with occasional limp-home mode and ASR light happening at random times — often when traveling at high speed and when on and off the throttle. It was intermittent and also always resettable by turning the car off and then back on again.
Pulling detailed codes showed 1-2 that indicated the NSS (I confirmed this off-board with the Bhagwan of Boise, aka the Maharaja of Middleton) and another code or two that are typical when LHM occurs.
Job took about 1.25 hours, mostly because I was on my back (the car was on ramps) and the shift linkage clip was being a PITA to get back on. I probably tried 15-20 times before I got it.
The job is a fair bit more difficult on the E500E than it is on the pedestrian 124 models, simply because there’s less clearance on the side of the transmission on the .036 models.
I used the short end of a 3mm Allen key to align the shift arm so that I could tighten the NSS into position.
A couple of test drives later (including some spirited driving) and no issues. I will take the car for a long drive (say into DC or Baltimore) before I consider the ASR demons excised.
Also I will open up the old (original) NSS to see what it looks like inside. I could tell the internal contacts are worn, because the new NSS arm moves much more stiffly than the original NSS does.
I checked the forward shift linkage bushing (on the removable short arm that clamps onto the NSS) and found it to be in good shape, still pliable and not physically degraded.
I'll be heading to Ronald Reagan National Airport today (in Washington DC ... well, technically directly across the Potomac from Wash DC in Virginia) and will take the E500 with me to really give it the test drive it deserves. It's about a 45-minute drive from my house. If the LHM doesn't come back, then I'll know the problem has been solved. I will pull codes again when I return later this week.
I opened up the old NSS by drilling out the five rivets last night, but didn't see anything conclusively that was a major problem. The circuit board inside the NSS did smell a bit "burnt" though; and there was some fluid (ATF or oil) / moisture on the outside of the NSS. Looked like there may have been a little surface corrosion at the plug, as well. I cleaned everything up before re-installing it.
For reference of others, the codes I pulled that pointed to the NSS are as follows:
  • Diagnostic Module: Code 5 (EGR inop - due to a plugged EGR tube that triggers a CEL) and Code 6 (ISC idle speed control inop - common "companion" code when LHM happens)
  • Base Module: Code 5 (CAN box temp exceeded - a BS code) and codes 11-13 (voltage supply to the four fuses interrupted)
  • EZL/DI Distributor Ignition: Code 11 (EZL resistor plug faulty - a longstanding code I have had with my modified resistor plug per the BergWerks NOS system which requires it)
  • EA/CC/ISC Electronic Accelerator/Cruise Control/Idle Speed Control: DigitalCode 007 (ETA bad or NSS failing to recognize transmission position) and Digital code 096 (NSS failure)
  • ABS/ASR Module: Detailed Code 30 (CAN bus signal to EA/CC/ISC interrupted - common "by-product" code of LHM)
  • LH Module: No codes
For the detailed "digital" codes noted above for the EA/CC/ISC and ABS/ASR modules, you will need a Star SDS or other type of reader such as a Snap-On or Trisco PalmScan to read them, as they are not available through the home-made "blink code" readers used with the mushroom adapters for the 38-pin adapter, or the 16-pin diagnostic port on the US-spec E500E.
The only other logical cause, as shown by the codes, would have been the ETA. Which, in my car, is still original and has the "biodegradable" internal wiring, having not been yet rebuilt. I am going to have this done over the winter as part of my coming "E500 Top-End & Front-End Refresh" project.
I hope that these codes and description are helpful to people in the future who experience LHM and ASR problems. It is an excellent idea to purchase a spare NSS now, to have on hand, because yours WILL eventually fail. Today they can be purchased from MB reseller sources online for around $95, discounted price.
Thanks to GSXR for his confirmation and advice in the "code interpretation" process.
Just ordered one from Naperville over the weekend. I am having intermittent wondering idle issues on my non-ASR car that can be corrected by simply restarting the engine. It's been years since I changed the NSS, so for $90 it's worth replacing anyway. I wonder how long it will be before those go NLA. I'm thinking I should have ordered a few more just to have in stock.
It is a part that is specific to the .036. I am ordering a new one with the parts order I am putting in this week. I had the last one on hand for 14 years....won't hurt to have another spare one for another 14. It was one of the very first spare parts I ever got after I bought my E500 in late 2003. I also got the brake switch and the idle speed switch that goes behind the gas pedal at the same time. Thankfully have not had to use those yet. Some of my oldest spare-parts.
Greed Hoarding is good.
Oh, no! I ordered part 000 545 62 06 for my E420 thinking it would be the same as the 500E.:o
I don't have access right now to my EPC. Does anyone know the equivalent NSS part for an E420? Thanks.
It's not really .036 specific. That same 000 545 62 06 switch is used on every LH vehicle with a 722.3 transmission. You're good, Jon
Great! Thanks, Klink. I probably already have an extra in my stock from years ago, but saw Gordon Gekko's post and figured why not.
Sorry — My bad. I didn’t mean to mislead as far as literally saying it was .036 specific; I knew the part is also common to the 034 as well. Didn’t know that other LH cars on other chassis used it.
I was thinking of other 124 models that were non V-8s when I made the statement.
Again sorry to raise your heart rate !!
