OK. Well, the R129 transmission should bolt up (AFAIK) but the tail section is different. I believe you'd have to swap the tail section with your existing transmission.
Why not repair / rebuild your existing 500E transmission instead?
this 500E i never use it since 8.5 years and this transmission issue appear after the paint job ,this is the second time with transmission issue i prefer the manual transmission swap , what about e320 manual transmission ? the 5 speed cable transmission from 300E-24 ?
Manual transmission swap is a completely different discussion. I'm not sure if the W124 6-cyl 5-speed transmission is a good fit or not. I'd look into a modern 6-speed with overdrive.
Read this thread for more info... a guy swapped a 6-speed Mercedes transmission into a W124 E420 a few years ago.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
