I am the proud new owner of Maui's first 500E. I will start a new owner thread soon, but had a couple of questions about how the car is shifting.
The car has a FGS installed and it is activated by moving the child safety window switch. Some observations when the FGS is activated:
From standing start, at WOT car will not shift from 1-2...engine hits the rev limiter and wont shift until I reduce acceleration somewhere around 5000-5200 rpm.
With FGS deactivated, I observe the following:
Car will shift fro 2-3 ok, but has a flare or pause to it. this is exaggerated at higher rpm's. Have not taken it to 6000 rpm from 3-4 as I don't want to go to jail
Car will not shift from 3-4 until 3000 rpm, no matter if it is a gentle acceleration or a hard acceleration. This is a little annoying at speeds around 40-50 mph as the rpm's sit around 2900 in 3rd gear.
Do you think the kick down switch could be causing this? I'm also wondering if the shop who installed the FGS maybe messed with the shifting points.
At what rpm does a 500E normally shift at for each gear? I'm guessing what I'm experiencing isn't normal, especially the no shift from 1-2, but wanted to get the board's opinion.
Thank you in advance...it is a great car! Gives my Porsche 928GTS a run for it's money!
