Hi everyone,
I have searched the forum but could not find a case with the exact combination of symptoms I am experiencing, so I decided to ask for help.
I am working on a Mercedes CL420 (M119 with E-GAS / EFP module N4/1) and I am chasing a persistent limp mode issue.
Symptoms:
Fault Codes:
From EFP (N4/1):
Work already performed:
Testing / Measurements:
S29/3 (idle speed contact switch):
Additional observations:
Key question:
Given that:
Is it possible that the E-GAS / EFP module (N4/1) itself is faulty?
Or alternatively:
Has anyone seen a case where:
I can also perform resistance measurements directly at the EFP connector if needed.
Any ideas, known failure patterns, or specific diagnostic steps would be greatly appreciated.
Thanks in advance!
Symptoms:
- ABS light comes on immediately with ignition ON
- Vehicle goes into limp mode
- Throttle response is limited
Fault Codes:
From EFP (N4/1):
- 096 – Starter lockout and reversing lamp switch (S16/3)
- 224 – Idle speed contact switch (S29/3)
- 030 – CAN: No reception from EFP (N4/1) or fault in EFP
- ETA (M16/1 throttle actuator) professionally rebuilt (Kurth Classics, Germany) and confirmed fully functional
- Wiring visually inspected (engine bay + accessible areas)
- Extensive live data monitoring performed
- Transmission range recognition (S16/3 / NSS) works correctly in live data
- Reverse lights function correctly
- No obvious issues with throttle linkage or mechanical setup
- Measured directly with multimeter
- Pedal NOT pressed → open circuit (infinite resistance)
- Pedal pressed → approx. 1 kΩ
- Values are stable and repeatable
- S29/3 switches state immediately and consistently when pedal is pressed
- Signal appears logically correct at all times
- M16/1S2 (idle switch inside ETA):
- Generally behaves correctly
- Occasionally flickers ON/OFF briefly (approx. every ~20 seconds with ignition ON)
- I have seen this mentioned elsewhere as possibly normal behavior
- No obvious mismatch between S29/3 and M16/1S2 during normal operation
- Gear recognition (S16/3) appears correct in live data
Key question:
Given that:
- ETA is rebuilt and confirmed OK
- S29/3 measures correctly and behaves correctly in live data
- S16/3 (NSS) appears correct
- CAN fault (030) is present
Or alternatively:
- all signals appear correct in live data
- but faults are still triggered due to wiring issues, grounding problems, or internal EFP logic faults?
Thanks in advance!
