Hi All,
I am a UK car Owner here in the UK and the reason for my post is to thank the author this thread in the WIKI as it saved me so much time and hassle:
http://www.500eboard.com/forums/showwiki.php?title=Viscous_Fan_Clutch
I have owned my car since 2008 and it has given me very little trouble although always run a little hot for my liking... Previously I had already replaced the radiator, A/C Condensor & fan Switches and Fan Relays.
This summer the car started to run over 100 and would climb beyond in traffic so I decided to tackle the water pump, thermostat and viscous fan clutch in one hit...
Well the water pump was the most difficult... Of course the radiator, fan pulleys and water pump pulleys must be removed. Also the main crank pulley balancer has to be loosened off... Do not need to remove centre crank bolt but do need to remove the 13mm bolts to be able to loosen the vibration damper off, as the bottom water pump bolt cannot be removed otherwise...
There is a guy on here that claims to have done it without removing this but I really cannot see how!
Its listed as a 4 hour job and it took me that and more to do
Also worth nothing that my "Vemo" fan clutch lasted less than 100 miles before it split and released gunk all over my engine bay... I was not happy... This has been returned and I have now fitted a Febi Bilstein part which I hope will last longer.
I think my root problem was the water pump as even with the broken fan clutch, with just the new water pump the car sat at 80 degrees most of the time.
I used a genuine MB water pump...
Very satisfied now as its been something ive been wanting to get sorted for years.
Awesome !
