The size exceeds the USPS limits for most, if not all, countries. Weight isn't a problem, it's the dimensions.I seriouls would be interested in at least 3 sets. I have shipped stuff to Indonesia vis USPS, why is shipping an issue?
See the following for a % increase in stiffness as the bars get larger: http://www.whiteline.com.au/docs/bulletins/BL-281.pdf
FWIW, going from stock 28mm to 30mm would be a 32% increase in roll stiffness. Those of us with staggered wheels, would really benefit from a 20mm+ rear bar...
A stock 124 bar won't work - needs to be a stock 500E bar due to some special bends for clearance.
I'm also interested in this production run. I would take one set, front and rear. Maybe we can combine shipping with those who live other side of the pond..![]()
Australia |
Belgium |
Canada |
Denmark |
Estonia |
Finland |
France |
Greece |
India |
Ireland |
Italia |
China |
Cyprus |
Latvia |
Lithuania |
Luxembourg |
Malta |
Netherland |
Norway |
Poland |
Portugal |
Russia |
Singapore |
Slovakia |
Slovenia |
Spain |
United Kingdom |
Sweden |
South-Africa |
Thailand |
Czech Republic |
Turkey |
Germany |
Hungary |
USA |
Austria |
Hi guys.
If you cant make this happen. And the reason im saying this is, because you have talked about this for about 3years now.
I have talked too Ake at Hedgehog Tuning and Motorsport in Thailand. And he will have no problem in making front and rear swaybars. In 32mm front and 20mm rear.
For my rear W201 bar, it was about $200 total and took about 3 weeks to arrive at my door.
For a DD [daily driver], no.Just curious - is anyone on the forum really interested in poly bushings?
I've never been able to get accurate dimensions for the E60 springs... rough numbers, but probably 5% margin of error, if not worse. Maybe we can convince Ron to get some good data from his shiny new set.I pretty much just need the dimensions and spring rates, there rest I can get made to spec.
Yep. Dunno if it did much besides lighten my wallet, add weight to the front end, and reduce body roll a little...So does anyone have a renntech bar?
Different cars. 92 had H&R, 94 has the 32mm sway bar.Dave, were you able to gauge how the car's body roll was affected with H&R springs? Did you have the renntech bar on at that time?
Stock 500E bar is 28mm front (22mm at the ends), rear bar is 18mm. Pretty sure most folks are interested in 30mm (AMG) or 32mm (RENNtech) front with probably 20mm rear?got around to looking at the bars. the stock front bar is 22mm and the rear bar is 13mmm The rear may be a stock w124 bar and not a e500. What size bar were you guys looking for int he front? I was going to balance the rear bar to match. Other wise the cars are just going to push like a stock 126.
Yes, in the 500E/E500 forum, not that silly W126/C126 subterranean forum.My eyes tell me that the topic is about AMG and RENNtech swaybar reproductions.![]()
