The switch/relay/wiring should work, but you will need to figure out what wires to interrupt on the M104 ASR module. I don't think I've read of anyone doing this. Steve Geyer or Russell Drake may know.Would this be compatible with a m104 w124?
This is medium/advanced DIY. You have to remove all modules and partly disassemble the CAN box, then cut & splice wires in the main harness below the ASR module. Also have to remove passenger airbag, disassemble HVAC console area, route wires through the firewall, and do some more splicing inside the car. If you're not comfortable with electrical work, go slow & careful... takes me 4-5 hours but I'm picky about my electrical work.I'm interested. Could you elaborate on what exactly needs to be done to install this? Specifically, if wires need to be spliced and where. I'm weak in electrical knowledge. Thanks.
 (Same here)
  (Same here)
I am also interested - please PM me once you have the kits ready. Can you advise if instructions will be given to finish the install off? I will go with the ASR button in the console for ease of turning it on/off as/when - something like this would be nice.
Does anyone know if MB sells the wood console trim which has all cut-outs to add extra options? Or do the holes have to be drilled?
OK maybe I am missing something here. I was under the impression if an ASR defeat wiring / relay configuration was installed like this one would simply pull out the "Snow Chains" Button on the upper console and replace it with a modified R129 "ASR Off" switch exactly like is shown in e500.org's post above. Is that not the case???
Correct me if i am wrong on this
Snow chains does let you have some spin on one tire. Not maniac spin. It will also reduce power to put less stress on the drive train. And only works to 60km/h (35 ish mp/h ?)
...ASR delete will take the complete ASR function away. Power reduction and skid control (tyre slip). And it will not generate error codes in the ASR system. And you still will have ABS..
...but IMO turning ASR off is for track-only use, or hooning...
Another stupid question... Isn't there wiring for the switch lighting?
Thanks for the diagram and method.
Stupid question,
the blue, yellow and green wires that go out of the diagram to the top, where do they go?
cheers
You mean everyday driving....??Precisely...
Martin, how much in Euros or Sterling to UK ? Also, could you post a photo of the prototype once it's ready, please ?
Cheers
Bing
(Same here)
Eric
But, Eric I thought you were an electrician and you have the master mechanic Matt Stockwell.
Stupid question,
These wires are the specific blue, yellow and green wires from the existing socket harness connecting to the ASR CAN module. These wires get cut & then each cut end is spliced to the corresponding relay IN & relay OUT wires associated to these three circuits (throttle, braking, dash indicator light).
The most important fail-safe relay wiring consideration is to ensure that if a relay were to fail, ASR remains ON.
Hi, I'm also interested in this mod. Just have one question - will the "ASR Off" switch fit into the fader switch hole?
So i only had white cabel at home in the right size. And the lengths are not quite right. This is just an example of how this will be. Every cable will be in different color but ground of course. And the diagram will be the same as in the real harness.
Some stuff is not there. The switch will be separate with connectors in such way that it cant be connected wrong.
Grommet to stop water to getting in to the CAN box will be on the on the harness at the correct place.
I don't know if the relays have to go out side the CAN box or in the bottom. The rain surprised me to day when i finally got the box completely dismantled. Might get time to have a look at that tomorrow. The only different if they go outside the box is that you have to drill two holes (7.5mm) in the box. If i was only to do one, you would have to use a step drill. And thats maybe not something everybody has.
I'm ok with full payment with ASR switch .
