Just to update, both cars eventually started passing small amounts of oil again in one or both caps... leaving me embarrassingly stranded in petrol stations and car parks. The worst is outside kids school in a busy car park and my car starts to pop and bang.....
Luckily i am now carrying around 5mm allen keys and brake cleaner cans!
So i bought the front covers, seals etc etc and did it "properly".
So what have i learnt?
I think the issue with replacing without removing front covers is, that no matter how good your tool, you cannot clean up the end of the camshaft properly.
I found that when the end of the camshaft is in front of you, the issue is obvious. A relatively thick layer of dry corrosion will make it difficult for any rotating rubber seal to effectively do its job.
I guess this may not be such a problem in some climates but condensation within an engine is going to be pretty normal so i would have thought it would be a universal issue.
When installing the seal with a new front cover (pre pressed into the cover), with the camshafts cleaned up, the seal glides on effortlessly.
Now i will need to test both cars but i feel much more confident that this issue is behind me now.
Also its a more satisfying job, new sealant on the cam magnets, new rocker cover seals etc.
Ps i have worked on M119 for years... i dont remember the back corner rocker cover bolts being such a PITA!!
I used new front covers just because I didnt want to do this job for the umpteenth time.
