The leak is always on the same spot, the passenger side, near the drain plug and closer to the rear corner, about 1.5 to 2" off. I checked the transmission carefully, but I could not detect any defects on the transmission flange on that spot. I did find the new MB oil paint not exactly flat at that spot and did some filing to make it flat (as far as I can tell).Is the leak at the driver side or passenger side of the pan? Front or rear?
Yep... there are several things on the passenger side that can cause a tiny leak. The Bowden cable O-ring and B1/B2 covers are the most common, and also the end of the pivot shaft that is visible on that side (this can be covered with RTV if leaking). Less likely, but possible, is the dipstick tube O-ring.Could it be possible that there is a leak above the transmission housing? There is something on the transmission housing on that side, the passenger side.
I think that I can confirm now that there are leaks from the top. Left over night over 12 hours, there are some fluid in the container. Went under the car and touched the transmission flange above the pan. It is oily, indicating the leaks from the top as well. Every time you have a problem with multiple sources, it gets quite complicated. I had oil pan deformation, gasket failures, plus leakage from the top. With a new pan, new gasket, and RTV, I believe that I had eliminated these these sources, leaving the only causes as those four arrows shown by Dave. Most likely, it is the second arrow from the left in the image from Dave. I will spray some starting fluid and apply some RTV as the last attempt.Yep... there are several things on the passenger side that can cause a tiny leak. The Bowden cable O-ring and B1/B2 covers are the most common, and also the end of the pivot shaft that is visible on that side (this can be covered with RTV if leaking). Less likely, but possible, is the dipstick tube O-ring.
I will do the dipstick tube. The other three, B1, B2, and Bowden cable unit are beyond my skill level. I heard it from the local MB shop that the transmission could be shifted to give more room for servicing the Bowden cable unit.All of the seals in the photo above can be replaced without removing the transmission from the car, but it is not fun. The B1 cover is the worst, the Bowden cable is second most unpleasant. B2 and the dipstick tube aren't too hard. Applying the blob of RTV at the external shaft, right next to the center pan bolt, is easy.
Thanks a lot. I watched a few videos on this but lying on the ground to fix something is not a favorable job of mine. I might get a quote to see how much it costs for professional help.Stop leak products rarely work well, unfortunately... and it can take hundreds of miles / many hours of driving to see if they will swell seals & reduce a leak, or not.
If you definitely have a leak from the B2 cover, you're in luck, B2 is one of the easier seals to replace. It's not fun due to the limited space, but there's no high-pressure spring fighting you like on the B1. The B2 cover O-ring is 005-997-70-48, $4.70 for OE/Genuine. The cover will press inward a few mm, then remove the retaining circlip, pry out the cover, replace O-ring... installation is the reverse. Just make sure no dirt or debris falls inside while the cover is out.
:jon:
The leak from B2 has become so bad. I placed a piece of the blue paper towner under B2 and a little tip hanging down. Over night, it leaked easily 100 CC of fluid. Looking under, I can see the dripping of fluid from the tip of the blue paper. The oil pan is dry. After overcoming one problem, now comes another. If I fix the B2, B1 is next in line. It is officially a parts car. Will take out the insurance today and surrender the license plate.I think that the stop leak probably did more harm than good. It was a hail merry attempt. Drove the car again to work and the leaking is pretty bad. Now, I am not sure if the oil pan is sealed or the B2 has become so bad.
I am wondering about the Odd of oil pan and B2 failing at the same time. I think that they might be related, one triggering the other. I think that the over-torque deformed the oil pan and eventually damaged the rubber gasket. The leak progressively became worse. Due to the leak, the transmission was under filled, which might have led to higher temperature. In some way, it led to weaker B2 seal.
I will let the car sit with a container underneath. May be next summer I would be motivated enough to try the B2 reseal.. For now, I will enjoy my 1992 sportsline.
jftu105
