Alright this is a bit of an open ended discussion. I'm only scratching the surface but the Ford Modular Engine I'm most interested in is the 5.4L in the 2000 Cobra R and its similarities or what could be learned from the 97-2001 pre-coyote and forced induction Mustangs 2003-Present. I know a lot of people run Ford EDIS with Megasquirt, but that might be moving too far ahead as I haven't fully covered the fundamentals of why I think these two engines might have more in common than the M119 does with the Porsche 928 32V V8.
My thinking goes something like this, all Ford Modular Engines from 1965 onwards essentially are Cosworth derived Keith Duckworth designed technology. Twenty-years later Mercedes hires Cosworth for the w201 as we all know to further develop the cylinder head camshaft combination mantra so to speak... Then Mercedes ditches the SOHC M117 for a DOHC 32V, and does anyone know if the camshaft profiles on the 102.983/990 are anything similar to what is in any of the more aggressive m119 versions? Lastly, Mercedes goes back to the SOHC M113 technology circa-1998 because its 30% cheaper to build, more EPA friendly, and it plugs well with the Daimler-Chrysler bread-and-butter that looked so good on paper at that point in time.
For anyone who doesn't know Keith Duckworth + Mike Costin = Cosworth. Feel free to fill in any gaps if anyone here knew Mr. Duckworth OBE personally.
Any thoughts??? Bueller??? Is 7500rpm out of the question with the right top end breathing modifications?
I'm sort of babbling and this may belong in the Performance Modification Forums or it might not even be on topic, but is the Mercedes M119 really all that different, mechanically speaking, from a 2000 Mustang Cobra R engine outside of the 400cc in displacement, coil-on-plug ignition, and its obdii compatibility?
