Hello all, just signed up!
I've owned several W124 (E320, 230CE, 300CE24V) and W201's (2.0, 2.3 16V, 2.5 16V) before and now after owning newer BMW's and Jeep's I really miss the good old merc's. Rides better and easy to work on yourself (+ you don't see the $1000 depreciation each month). I've never seen an 500E in person, but the "wan't feeling" has been present for a while now. Looking into purchasing it as a daily driver as I have enough ground up restoration cars.
How is your 500E ownership?
Are parts easily available? Servicing parts I expect is available, but how about ECU, relays and other parts that usually fails with age? Is it an idea to switch to Haltech, Megasquirt or similar systems to reduce error possibilities?
What are common faults on this model? I expect the "bio-degradable" wiring loom needs to be changed out as other merc's from the same era, how about other issues?
Is it well built or is the V8 conversion a bit of a fast job done by Porche? Heat issues, weight problems (structural) etc.
I see there are some low milage cars available on mobile.de (less than 50.000km). Is the extra money worth it compared to a well maintained 150k+ km car? If there was any production gremlins I expect it's sorted after 100k km.
Is there any years that's better than other? I do prefer the pre-facelift over the facelift.
Budget will be about $20-25000.
Thanks!
Thanks!
